#16 | |
Try this place. They sell HD back focus charts for $97.00 http://www.testequipmentdepot.com/ I hope this helps, Carl |
#17 | |
#18 |
Capt. Quirk
Somehow, I think she'll be the one that would end up with all my video equipment.
www.SmokeWagonLeather.us |
#19 | |
The difference on the high end cameras is that you need to regularly check the back focus. Every time you change a lens, if the temperature changes you have to check the back focus. So, focus pullers (1st AC in USA) are checking the back focus throughout the day and setting up charts takes up time when time is an expensive. It can also be difficult in confined spaces. It then becomes worthwhile having these more expensive optical units: it saves time, especially when using prime lenses - you don't need to measure distances. On a feature film, an extra set up at the end of the day could pay for the unit. A point to remember is that the production will often hire items like this as part of the camera kit. |
#20 | |
Capt. Quirk
#21 | |
#22 |
Here is the Panavision Chart. You can print this on 11x17" and 600dpi printer.
Click here for PDF Have fun back focusing.
Advanced Avid Liquid Training found Here |
#23 |
Capt. Quirk
Thanks Stephen, I've been having soooo much fun as it is. It's at the point, I'm not sure if it's the cam that isn't focused, or me. It goes either way some days.
#24 |
Peaking enhances the highest visual frequencies in the image, such as sharp edges, while leaving softer edges alone. So when you achieve perfect focus, the edge will appear to pop out. I've worked with camera operators who can't stand peaking for whatever reason, but it's their loss, peaking is really the best way to know exactly when you're in focus especially on a smaller viewfinder or one that is a lower resolution than the camera.
#25 |
Kino-Eye
Being of the mind of "maximum performance" for "the minimal price" as long as there is "no sacrifice in quality," for years I've been using a Siemens Star chart for back focus adjustment and checking focus when setting super-accurate marks that I simply printed out myself with a high-resolution printer. Any printer 600 dpi or better will do just fine, no reason to spend money on fancy charts, put the money on the screen.
Stephen L. Noe included a link to a Panavision chart, this PDF is courtesy of the nice folks at JVC: http://www.jvcpro.co.uk/getResource2...t1.pdf?id=6145 and it includes along with the Siemens Star Chart some instructions on how to use it along with a little history, the chart was developed in the 1930s by German industrialist Werner von Siemens in order to set up the focus on the film cameras he was manufacturing and the rest, as we know, is history.
David Tames { blog: http://Kino-Eye.com twitter: @cinemakinoeye } |
#26 |
Correct me if I'm wrong, but do they not include this chart in the camera's manual? Also, just curious, how often should this back-focus be performed if we are not changing lenses?
#27 |
"It's one of the worst designed sites I can remember seeing recently. I don't think they have warm cards... but hey, with a navigation system like theirs maybe they do. ;-)"
Their cards are so expensive to make, they couldn't afford a decent web designer...
"Keep doing projects" |
