freeware capturing and PCM capturing at DVinfo.net
Old May 28th, 2006, 03:59 AM   #1
Hi folks
I still have problem to capture m2t in 25FPS under HDV format.
does anyone used HDVsplit?
I am cheap, using freeware and virtualdub to do most of the work
i got a celeron 800 pc only.
i m happy to know more if anyone did the PCM sound out from HDV, could winDV capture it? great freeware for DV capturing and killer is timelapse setting.
right now i can only capturw with CapDVHS at 50fps and use virtualdubmpeg2 to convert to 25fps sync with audio.(any codec u prefer)
is there any better way?
thanks
JY
John Yamamoto is offline   Reply
