#31 |
I have answered my own question and have found that the instructions need a few small additions:
1) Make sure the camera is in 24p. 2) Only one Focus Assist button will work in this operation. Use the button next to the Peaking adjust knob on the left side towards the front of the camera. The Focus Assist button on the handle, while technically on the camera, will not work nor will the RET button on the lens if it's changed to Focus Assist. 3) Turn off Focus Assist if it's on. Press and hold the button then press and hold the Menu/status button. There you go - Service menu!
William Hohauser - New York City Producer/Edit/Camera/Animation |
#32 | |
JVC America
Oh, I see now that you figured it out! Regards,
Carl Hicks JVC Professional Products Company |
#33 |
Carl how many times can this be performed before the masking buffer fills?
#34 | |
Carl? john evilgeniusentertainment.com |
#35 | |
JVC America
#36 | |
excellent! I REALLY appreciate that feature btw. |
#37 |
Just to be sure. I guess the lens cap must be on to perform this function?
#38 |
No other warranty will be void after performing this yourself? The european service guy told me here that after a certain number of times a hardware change was needed (don't ask me od what exactly), so I'm a bit weary of doing these things myself...
High-Definition Video Consultant - CEO of Delimex NV - http://www.delimex.be gear of choice : http://www.wespgear.com |
#39 | |
JVC America
The key thing is to make sure the camera isfully warmed up. An hour turned on prior to running the proceedure is a good idea.
#40 | |
JVC America
Here in the U.S. there has been no warranty issues wih this proceedure that I know of. I can't speak for other country's policies.
#41 |
Carl - thanks for the info! An hour, huh? Good to know... Does jacking up the gain help in any way?
#42 | |
JVC America
#43 |
HD100 Repeated Dead Bad Pix
Hey everyone - just finished up reading this thread...thought I'd share my experience on this issue. I have an HD100 (still under warranty) that I've had repeated, and uncommonly bright bad pixels develop with on a regular basis.
I fly a lot and so have been very careful to keep my eye on this issue and at first I thought the highly touted pixel compensation menu was the solution. However, this has not been the case... I have now had three subsequent shoots marred by significant dead pixel issues on this camera in fairly quick succession - one in Antarctica, one in Cambodia, and one in Oregon. I should note that in each instance prior to pixel loss: 1. The pixel compensation program was run on the camera AFTER the camera was fully warmed up for over two hours. 2. The pixel compensation software was run AFTER each flight I made with the camera. 3. The problem has developed within 3-7 shooting days of the start of each shoot. Of course, if I could I would simply shoot everything with a field monitor to be sure dead pixels aren't developing....but as we all know, this isn't always possible. My thoughts are that a shooter shouldn't be expected to have to run pixel compensation software prior to, and during each shoot, never knowing exactly when - if at all - bad pixels have, or are developing. To me - regardless of what manufacturers may say to protect their product - this is a particular weakness in this particular camera. I've NEVER had this problem except with JVC cameras (and I have two at the moment - though at this point I may never buy another). My current hope is that JVC has been able to address this weakness in subsequent models as it seems an inherent weakness in the HD100...at this point I'm just trying to figure out what to do with a new camera I can't trust. -Skye |
#44 |
Thanks you guys soooooo much!
I was freaking out about my lit pixel and BOOM that dang procedure fixed it! I owe you guys my career!
Thanks JVC. dave PRODUCER www.mediaflycreative.com |
#45 | |
Contributor
The problem you're relating (3) seems different to standard dead pixels - I'd be returning the camera for a replacement as soon as you can, or if that is not possible at least sending it in to JVC for evaluation. Hope all works out for you. |
