capture GYHD101E with capVHS but got 50FPS
hi , i had some m2t captured on CapVhs but seems the frame rate is 2x at 50fps, it cost a problem when i place on some software time line, the vidro is 1/2 way shorter than audio.
i did use virtualdubMpeg2 to encode into cineform and set at change to 25fps and process all frames is there anyway to capture it directly into 25fps? i use a lousy ( well i love it) celeron 800 to do HDV editing. so freeware is a solution to me. thanks JY |
RE 720p/25
Hi,
I have found DVHScap To capture ok and MPEG Streamclip to convert, There is alot of setting, i havent got one that i can drop in FCP but can capture 720p/25 and it looks exelcent!!! Played buck in QT. If any one know the settings let us know plz...i will keep testing .. rob. www.rpbproductions.com |
capvhs 50fps issue
i wish to know more if the clip is at 50Fps when captured by Capvhs
and then converted to 25fps? thanks JY |
