Using My Canon Camera As Caputre Device
I have a MiniDV Canon ZR-500, and am shooting a movie this summer in SD/24PA. I have run a few tests with the HD100 in 24PA mode, and have used the Canon to caputre to FCP. The first test went fine, the last two had a timecode problem. I thought that any camera can act as a deck with 24PA material?
You're right, any camera will work, but if theres minor head alignment issues between the two cams, there will be errors in the DV stream that will throw off the cadence for FCP
My Work: nateweaver.net |
#3 | |
#4 | |
Can i use my old miniDV camera to capture the DV & HDV footage? Pop in the ProHD tape in, and capture via firewire to PPro/Liq7 (potentially saving the HD100 head wear&tear while capturing + reduced number of hours)
http://www.wizedot.com |
#5 |
No, the only way to reproduce your JVC HDV material is to use: HD100, the BR-XXX deck or the CU-VH1 "spooler". DV can be reproduced with any MiniDV camera.
Luis |
#6 |
Hey I did the same with my canon optura 60 camera and editing it on vegas 4 and it worked flawless. Shot in 24pa and vegas automatically detects it and edits at 23.97. Then burned it to a dvd and NO PROBLEMS.
My computer is not enough to edit HDV so I shoot in SD which works great. |
#7 | |
What other camera have been used that work, and is an old JVC camera a better option? |
