#31 |
You're very welcome John.
I'm glad this has been of help. |
#32 | ||
are well within the ATSC broadcast legal envelope. Yours will be just about the same. Generally, the Skin Detail setting (on) will desaturate reds somewhat and spike a very narrow range in the yellow spectrum down. You are using the HD100 to match film, I only use it for broadcast. I'm fortunate enough to use film cameras for film. But, I will post more later on several on set comparison tests ("on the fly") I have done with the HD100 vs. a S16 Arri, A Pana Genesis, and several Arri and Pana film cams, plus the VariCam and CineAlta. I think JVC is just starting to scratch the surface as far as making the HD series a "real" film camera alternative. And I think the split eyepiece is a good indication of that. It makes a perfect jumping off spot to add an eyepiece extender so the cam can be used on a gear head. For a straight to DVD 16:9 movie, you are not going to find a better cam under 25K, period. I have tested all the other HD cams, about 40 hours worth on each (about 80 on the HVX200), and they are all great for the price point they are selling at, but the JVC is better than any of them (in my opinion -- more on this later also). Can't post clips or even frames from my Cannes footage due to copyright and embargo issues, but if you saw the CNN or any of the US entertainment based shows broadcast footage of "The Da Vinci Code" opening day, the Steadicam coverage of all the principals walking up the stairs and then into the press crowd is all my operating (using a HD100 and Steadicam F-24). We were on a pool feed, and ours was the only crew with a Steadicam. The F-24 is a perfect fit for the HD100 (used in both high and low configs), and even after a few hours of continual use, I still had legs :) I see that someone has a thread entitled "Turn Power Off Turn Back On Later". My HD100 must have been made in Italy, it says "Turn power off, have a cup of espresso, turn back on later". L'azione non significa pizzicare di fermata, significa appena il pizzicotto piů veloce. |
#33 | ||
No, it's not my taste in color that determines my color settings, it's what I know the output will look like in the broadcast envelope. I am constantly changing settings (on all the cams I use, not just the HD100) to match my frame. Paolo's TC settings are a good starting point, but the settings always have to be optimized for the frame you're shooting. I reduce both color AND _red_. Lucky for us (and JVC), the ATSC standard is pretty loose right now, but as you already mentioned, it has a pretty strong magenta bias. When you add broadcast engineers that have tons of NTSC broadcast experience and are just starting to work within the ATSC output frame to the mix, you get a strong red bias and oversaturated colors along with a lower gamma curve. The HD100 loves to shot more on the toe of the curve than most video cams, and I think this was a good approach for JVC to take. The downside is that failing to have enough HD experience, the broadcast engineer will set the mid point IRE lower than he/she would for NTSC output. As I do with film labs (I set the MY mid exposure to THEIR mid point light for the entire production), I am starting to set my color and detail settings according to the broadcast venue that is airing the footage -- when I can. Quote:
(higher gamma curve, more desaturated colors), but very little on a HD to SD PAL convert (mostly a little higher gamma curve). It makes a fantastic convert to DVD in a 16:9 frame. Really a strong but little mentioned aspect of the HD100. Of course we all know NOT to shoot the HD100 in 4:3 SD mode, it's not what the camera was designed for The HD100 is not really a true broadcast cam, but it's the best HD cam that can be used for HDTV 16:9 broadcast output available for under 25K. |
#34 |
embargo issues<< Embargo issues?
Boycott Guinness, bring back the pint!!! |
#35 | |
#36 | |
I know, it's a very confusing term :) I work in commercial broadcasting, and on studio funded films, so basically my output is on a "work for hire" basis. I don't own what I shoot, and most of the time, I don't even see the tape I have shot. It goes right to the broadcast outlet I am shooting for (but I do check my return video a lot :). An "embargo" in commercial broadcasting is a condition placed on the coverage you are shooting in exchange for a studio (or a celebrity's rep or agent) giving you access to an event or personality. In the case of Cannes, I was shooting for French commercial TV, Italian commercial TV, and doing a pool feed for several broadcast wire-services (domestic and international). Besides the common sense copyright issues (I don't have any rights to what I shoot on work-for-hire gigs), there was a Sony sanctioned embargo (condition for Sony arranging access) on all Da Vinci Code coverage to the US domestic market because it was an Access Hollywood broadcast exclusive for the North American market. Embargos are usually time, venue, or broadcast overlay specific (can't be shown before a specific date, or by a particular outlet, or on the Web, or a specific geographical area). In addition to the above, almost all the Cannes events (except for the table interviews which are pretty useless) had an embargo against any Web use of any kind on their granted access coverage (except for a few pre-approved outlets). |
#37 | |
It basically depends on what side of the pond you're on. In America we say "We saved France's a** during the 2nd World War". In France they say "We saved America's a** during the Revolutionary War". Like all things, your point of view is based on which side of the camera you're on. |
#38 | |||
My interest i the HD100 is based on my "digital background" (20 year of software development) and the fact that, for what I want to do, it's good enough. I might add the M2 along the way. Quote:
#39 | |
#40 | |
HDV Cinema
I watched "Umbellas of Cherburg" last night. Would love to re-see Godard's "La Chinoise" with each room painted a super saturated color. Or, maybe I just like the way the French and Italians used color. "Juliet of the Spirits," for example. I supose one could try setting an HD100 to a high level of saturation, designing sets, and adding grain in post.
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c |
#41 |
paolo, how to print out a color chart for test
paolo,
may i ask u a stupid question. I m interested on calibrate my JVC to color correct and exposure correct how can i print a chart? or any free downlaod? i use freeware virtualdub and a free filter to do vectorscope. however i main concern is to preserve the maximum of dynamic range for possible film output ( not cine-like gamma) so a maximum of DR is able to give me room to ajust with I also noticed that both MAC and PC are on 2.2 gamma any difference to the V3? i am still using V2 as i m happy with it. i disable all color because i prefer corect it at post thanks JY |
#42 | |||
The reason charts like the ones made by DSC cost that much is because they are printed with color accurate printers and they are verified with very sophisticated analysis tools in order to check that the charts return the expected amount and type of light that will position a given color in the right position in your vectorscope. You can't print it on you inkjet, sorry :) Quote:
Take care. |
#43 | |
Royale with Cheese
cutters to chop them in half :) |
#44 | |||
compete with a $6K cam. Hahaha, wish it could. But the differences are not all that great as long as you work within the limitations of the HD100. The biggest factor is the skill and experience of the DP. When I get some real time I will post my impressions of the on-the-fly tests between the various film cams and the JVC unit, but here's something to whet your appetite, the JVC output comes very, very close (intercut close) to the VariCam. You could probably do an A - B test on the edited footage intercut from both cams and not be able to tell which is which. Film is not a "look", it's a medium. I think what most people are looking for is something that looks other than video (because of the bias against, which is not totally warranted, but exists because of all the schlocky projects produced in the past on video). I believe the proper term should be a non-video look. My biggest problem with any video cam for film use is the DOF issue. When I set up a shot, my first question for the director is "what do you want to see". DOF is one of the most important tools a DP has at their disposal, and giving it up means losing one of our most important aspects in telling a story. Quote:
Also, I should have made it clearer, my only use of the HD100 in covering Cannes was on the Steadicam. I never did really get to use it or the 2 HVX200 we had with us (to be used as tape up, put anywhere cams) much. All my Cannes broadcast output (except for the Steadicam shots) was in PAL Digibeta 16:9 format. Last edited by Enzo Giobbé; June 8th, 2006 at 06:24 PM. |
#45 | |||
Enzo, I didn't see this till today. Sorry for the late reply.
Cheers! |
