#16 | |
#17 | ||
Thank for the compliments about TC. So, you're keeping the detail level quite high, eh? I'm interested in this. I found the level detail too "aggressive" and I'm constantly shifting between MIN and OFF. If you do broadcast work normally, TC might be reproducing "illegal" levels. Of course you can reduce them in post but you're settings require less manipulation. I'm aiming at making the HD100 as close as possible to film so I didn't check the values against broadcast levels. I never touched the skin tone circuit as I don't want to have other factors changing the parameters out of my control. I'm glad that you mentioned, it confirms my fears :) Quote:
Sounds like you're gonna have fun in the French riviera. We are all eager to see some clips or frames, if you have the chance. In bocca al lupo! |
#18 | |
HDV Cinema
You may be right that his shifting both Color Gain and Red Gain down one notch may guard against exceeding broadcast levels. (Although one would expect JVC would have set default Color Gain correctly.) Alternately, DSC makes some comments, I don't understand, about THEIR 75% color bars being too hot. If this is the case, there may be two TCs: TC-film and TC-video. By the way, these two links seem broken: Main scene Right side
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c |
#19 | ||
The DSC colors, if I read their comments correctly, will cause the NTSC VScope to reach 75% of the level. They suggest using gain for positioning the colors in the boxes. Thanks for link check, I fixed them. |
#20 |
posting of true color v2 in my documentary
http://img150.imageshack.us/my.php?i...vetsb404fb.jpg
http://img249.imageshack.us/my.php?i...liteer01yz.jpg hi, these are the captures from JVC 101E HDV capture using truecolor v.2. I set all color at zero. as i prefer the warmer tone. the lighter image was after adjusted the middle bar at levels overall brighten up and not losing an highlight details Jy |
#21 |
Thanks Paolo for your greatly appreciated work
Does you TC3 also increase latitude? We're using the HD101's live at the moment, and did a large fund raising concert on Friday night, but we found on standard settings, we had to run the cameras upto 12db gain. Just wondered if you settings would save using so much gain. Thanks
#22 |
Hi John.
Hard to rate the colors on that kind of image since there are very few colors, they are generally desaturated and you are shooting against light. Myself I would go for a darker image but I'm glad it works for you. |
#23 | |
V3 doesn't change the latitude of the settings. It gives a better balance and contrast but it's a small variation compared to V2. Depending on the type of concert you can use black stretch at 3, longer shutter speed (1/30 if shooting 30fps or 1/24 if 24fps, for example) and gain, and a combination of all 3 :) |
#24 |
darker i also prefer
Paolo,
I agree too, darker seems better in color saturation. but i just show what can be done in shadow and dark detail note that the man 's ear shown in shadow. I m not think in video so i only think in film ( not film look!) i have not to test a 35mm blow up but i think ur TC has a very sound and linear exposure latitude for blow up. as this is always confusing to many people that they mis-used film look or cine like gamma. i test with sony and found cine gamma is just a 3 stop cut. in plain exposure term -- how many stops ur TC v3 can preserved? i still prefer to use a spot meter with ASA/ISO setting for good zone system exposure allocation ( pardon my english) have u test that the JVC has a constant ASA/ ISO? color wise i rather do it in post, i actually prefer t o do it as im age sequence or use cineform for output JY |
#25 | |||
#26 | |
HDV Cinema
Have you -- or could you -- post a vectorscope of your V3 settings and a vectorscope with the Color Gain set to -1 rather than NORMAL and Red set to +2 rather than +3. If it turns out your V3 is too hot for Broadcast video, then you may want to post two versions: TC-film and TC-video. Lastly, could you find the time to post one second of .m2t V3 (film) and perhaps V3 (video).
#27 |
Hi Steve.
I'll shoot a clip of the DSC chart with TC V3 and I'll get a frame grab of the VScoper + histogram. I'll also post some outdoor footage probably tomorrow. Cheers |
#28 | |
#29 |
HDV Cinema
Looks like we have to wait for Enzo to return and explain why he slightly reduced color and slightly increased red. I wonder if that was his taste in color -- or if there was a technical reason.
For example, we know we can have very saturated red using HD. But what happens when we broadcast an NTSC or PAL version of an HD production? How about when we make an NTSC or PAL DVD? Does the conversion from HD to SD colorspace automatically reduce chroma saturation IF it is necessary to reduce it?
#30 |
Fasinating stuff guys!
Paolo and Steve - great work on this thread. Very educational.
Thanks again Paolo for all the hard work you've put in - and we'll for sure mention you in our credits. Keep up the good work guys! john evilgeniusentertainment.com |
