On a Jib Arm? at DVinfo.net
Old May 11th, 2006, 11:16 AM   #1
On a Jib Arm?
New to the Group...so has anyone used one of these on a jimmy jib or cammate? If so did you have to have a converter to see the output or was an HD monitor used at the operator position?
On another note I'm trying to find the pixel mask discussion...just in case...can anyone direct me to that?
Brett Ward is offline   Reply With Quote
Old May 11th, 2006, 12:02 PM   #2
You would probably want an HD monitor at the operator position to check focus, but the HD100 does have a standard def output if you can't get your hands on a monitor. You would need a monitor capable of squeezing anamorphic images, because the standard def output in unletterboxed widescreen.
Stephan Ahonen is offline   Reply With Quote
Old May 11th, 2006, 01:46 PM   #3
So if you are shooting in HD with it you can still output RT SD? Nice.
