How do I capture 60p VIA the component outs? at DVinfo.net
Old April 30th, 2006, 10:51 AM   #1
Alright, so i need to do slow-motion in the field. Thus necessitating the ability to capture 60P in the field. What components do i need and roughly how much do they cost?
Adam Craig
Los Angeles, CA
www.showiki.com - Entertainment Biz Wiki
www.filmexposure.org - My Media Company
Adam Craig is offline   Reply With Quote
Old April 30th, 2006, 08:34 PM   #2
There are a few uncompressed options.
1. The Wafian. Here's a photo I took at the JVC booth:
http://www.TimDashwood.com/.Pictures/NAB2006/Wafian.JPG
2. Decklink HD Extreme. Blackmagic just released this new card last week for $999. It now has analog YRB component in. I've used a blackmagic decklink before with the HD100/FCP/multibridge and it works well.
3. Kona is an alternative option to the decklink.
Option 1 is standalone. Option 2 & 3 require a desktop computer.
Tim Dashwood
Old April 30th, 2006, 09:54 PM   #3
One of my shooters "accidentally" shot a long form seminar in HDV 24p.
We captured through the component outputs and it worked great.
just coupled the outputs to the input of my blackmagic design multibridge extreme.
worked like a champ!
The footage was supposed to be DV24p, so we also used the built in hardware down converter in the multibridge and captured it as anamorphic sd. Turned out great!
Mark Silva is offline   Reply With Quote
Old May 1st, 2006, 03:30 PM   #4
When i use the DEcklink HD Extreme for capturing via analog YRB component, u think if it's possible to do the batch capture? BEcause i don't know if the analog YRB component has the time code out put or not.
Trung Dau is offline   Reply With Quote
Old May 1st, 2006, 08:05 PM   #5
Images: 11
Firestore FS4-Pro HD
When doing many test a few weeks back, I recall capturing HDV 60P to the Firestore copied it to my internal hard drive and loaded into a Premiere 2.0 HDV project. I had to render it but it was great slow-motion. I will test this again in the morning to make sure of the exact setting I had.
Chris Lognion
Chris Lognion is offline   Reply With Quote
Old May 1st, 2006, 08:49 PM   #6
Are you sure? As far as I know there is no way to get 60 fps out of the camera via Firewire except by shooting 480p. You can only get 720p60 by capturing the raw analog component output from the camera. The upconversion from 480p to 720p doesn't look too bad unless you're going to blow it up even further (i.e. film transfer or large format digital projection), but it's still not native 720p.
Stephan Ahonen is offline   Reply With Quote
Old May 1st, 2006, 08:49 PM   #7
Are you sure? What mode did you put the camera in to do this? I've very interested in capturing 60p with the HD100.
Adam Craig
Los Angeles, CA
Old May 2nd, 2006, 02:06 AM   #8
You're correct, there's no timecode. With the Wafian you get a bunch of .AVI (Cineform codec) files named the way you want, you'll have to slate the shots and synchronize sound manually.
It works pretty well, my main gripe is the UI, not nearly as good as it should be and you want to use the unit with a full size monitor and mouse.
On the other hand it seems to be working very well.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old May 2nd, 2006, 04:33 AM   #9
I thought 60p Via firewire is not possible on the HD100?
"eyes through a digital world"
Jemore Santos is offline   Reply With Quote
Old May 2nd, 2006, 09:19 AM   #10
Images: 11
Hdv-sd60p
OK here's the deal. I repeated the test I did a few weeks ago. It's definitely a 720x480 image. I place the camera in HDV-SD60P recording format and connected the Firestore FS4Pro HD set to record in HD. I then brought the file into a Matrox DV Widescreen project, The propery value shows 59.94 fps, I then interpeted the footage as 29.97 and it played back in slow motion. I'm not sure why it has to be in an HDV setting other than it is recording a true 60P image and DV cannot handle the data???
Chris Lognion
Old May 2nd, 2006, 08:57 PM   #11
The HDV stream is 60p no matter what, that's simply the HDV standard. However, the footage itself is 30 fps with a "repeat frame" flag on every other frame, embedded within the 60 fps stream.
