Power Supply Decision at DVinfo.net
Old April 26th, 2006, 10:49 AM   #1
I'm buying 2 HD-100s and I have some battery decisions. One camera will be run off & on for 6-8 hours per event and for that camera I definately can justify the IDX solution.
But the other camera will be run for just 2 to 2-1/2 hours per event. (only 90mins continuously at the max.) My lights have thier own power supply and so the only power requirement would be to run the camera. Using the largest available direct plug-in type of Lithium Ion Battery Pack available for this camera could I get by? If I had two of them? What is the largest capacity direct plug-in style of battery I can get for this camera? How much continuous run time can you get out of it? Anyone using a brand other than JVC with greater than 3800 mAh?
Thanks-
Craig Terott is offline   Reply With Quote
Old April 27th, 2006, 09:45 AM   #2
Can someone check my calculations?
HD100 power consumption = 17Watts/8Volts = 2.125Amps
battery pack 3800mAh = 3.800Ah
3.800Ah/2.125A = 1.788h
So my estimate is that I should be able to get between 1-1/2 - 2 hours out of the 3800 mAh battery pack?
Old April 27th, 2006, 10:33 AM   #3
I have been using the standard 2800mah battery on my HD -100 as I'm waiting for my Anton Bauer Mount to come in. The amount of time I get from the 2800mah battery varies from about 40 to 60 minutes of use, depending on whether or not you are using the LCD screen or viewfinder, recording or not. I would say that you would be lucky to get 90 minutes out of the 3800mah battery. Hope that helps!
Doug Harvey is offline   Reply With Quote
Old April 27th, 2006, 10:37 AM   #4
lol,make your own,I did and I don't even own one ;-)
http://www.glasseye.com.au/hd101e/battery.htm
Guy Barwood is offline   Reply With Quote
Old April 27th, 2006, 10:59 AM   #5
Thanks Doug for the "real world" input.
Check out this 4800mAh knock off. (I've had good luck with the knock offs. I have an 7hour battery for my PD-170 that I've cycled a ga-zillion times since 2003 and it just won't die.)
http://www.ibsa.com/estore/search.as...CRank%7C1&js=1
I'm just looking for a cheaper alternative to the IDX for the 2nd camera which won't exceed 2-1/2 hrs per event.
Old April 27th, 2006, 11:03 AM   #6
Guy, of course you know you put a lot of weight on that camera's battery mounts? But still - ur a genious!
Old April 27th, 2006, 11:06 AM   #7
Doug,
(I'm leaning towards) IDX over Anteon Bauer because of the way the IDX mounts. It tilts away from the shoulder and seems like it's a more thoughtful design. When you get your Anteon could you follow up and let me know if it feels restrictive at all for movement or if it comes in contact or rubs your shoulder? I'd like to know your opinion. Thanks-
Old May 3rd, 2006, 10:32 AM   #8
Craig - Thanks for the link -
Ram Ganesh is offline   Reply With Quote
Old May 4th, 2006, 12:31 PM   #9
One has to wonder why JVC just doesn't produce a higher-capacity battery pack. Not everyone has the budget for an IDX or AB system.
Earl R. Thurston, Stargate Connections Inc.
Made with GY-HD100: The Container Adventures: The Rescue
Earl Thurston is offline   Reply With Quote
Old May 4th, 2006, 12:34 PM   #10
Very resourceful. How long does that sucker take to charge?
