Thread Tools
Search this Thread
HD100 frame rate question
It may sound weard but I am a little confused. If I record with HD100 at DV60i 30p what frame rate should I choose when capturing - 30p or 29.97?
I use FCP5. Aplies it to the HDV formats also or not? (does it change if I record on tape or firestore?). Please reply. |
Many people are confused by this, and software programmers do not help the matter much. You should always select 29.97 when given the option. From a technical standpoint for Colour NTSC there is no such thing as 30fps. It is just an easier way to say 29.97 fps.
Tim Dashwood |
Thank you Tim, that was fast reply! Thanks again! (I assume same thing is with 60fs as 59.94, right?)
#4 | |
Tim Dashwood |
#5 |
Ok, now it all makes sense.
