Problems capturing FCP & HD100 at DVinfo.net
Old April 19th, 2006, 01:21 PM   #1
I am still having problems capturing, now with FCP 5.1 and HD100 (A rev).
FCP is set to 72030p preset. Basically FCP is unable to capture across shots. I have tried all sorts of things: capture now, logging clips, batch capture, User Prefs timecode break settings. Cannot capture more than one shot at the time. FCP either aborts or forgets all but last captured shot.No timecode breaks as far as I can tell. Is there some camera timecode setting I have wrong?
Also noticed since i got the A back that I get a "change 1394" error message in the JVC viewfinder except when tape is playing. The button is set to HDV, PB is auto (I also tried setting PB to HDV only, same error)
Anybody using FCP 5.1 and HD100A combo successfully?
Kaspar Stromme is offline   Reply With Quote
Old April 19th, 2006, 02:10 PM   #2
JVC America
FCP capture
Kaspar,
Are you having this trouble with tapes that were shot prior to the "A" upgrade, or on tapes shot after the camera upgrade?
Carl Hicks is offline   Reply With Quote
Old April 19th, 2006, 02:50 PM   #3
Carl,
the problem is also with tapes shot prior to A upgrade. I successfully captured those tapes previously.
One correction: I am not running FCP 5.1, it is 5.0.4
Old April 19th, 2006, 03:09 PM   #4
JVC America
Fcp
Kaspar,
Tapes shot prior to the "A" upgrade may have breaks in the time/date stamp in the subcode. FCP gets "tricked" by these breaks, and sometimes creates multiple clips. For tapes shot prior to the upgrade, they need to be captured on a non-FCP system, then recorded back to tape, then captured to the FCP system. This should create a continuous time/date stamp in the subcode, causing to FCP to correctly capture the clips.
Depending on how much "pre-A" footage you have, and your location, we may be able to help with this conversion process.
Regards, Carl
Old April 19th, 2006, 03:17 PM   #5
Carl,
I don't have a lot of pre-A tapes, so that is not really an issue. I am much more concerned with the fact that I cannot practically capture ANYTHING after my A upgrade.
I don't understand why when the camera is plugged into the Mac it keeps flashing "Change 1394 switch" when the tape is HDV? It did not do this before A upgrade.
Old April 19th, 2006, 03:33 PM   #6
JVC America
Kaspar,
Then I'm stumped. Try calling our tech support line at 1-800-582-5825, 9AM to 5PM, Monday thru Friday.
Old April 19th, 2006, 03:57 PM   #7
I was able to capture on an older G4. Not sure what's going on with my G5 but it doesn't like the HD100 very much... Atleast the camera's in the clear :)
