New HD100 Pixel Out - Page 2 at DVinfo.net
Old April 18th, 2006, 01:33 AM   #16
Originally Posted by Tim Ward
Eric,
. I wanted to get away form the small DV look and when converted down to SD the pics on the JVC look very good. The colour is not quite as rich but otherwise compares very well with Digibeta.
Cheers
Tim
what method/software are you using to convert to SD?
Old April 18th, 2006, 07:42 AM   #17
Hi Brian,
Quite basic really, play HD out of the JVC through the component connectors in SD and record in on a Sony DSR45 to DVCAM. I can edit the HD using Canopus Edius 3.6 and use it to convert HD to SD as well. The Sony as I understand will allow you to playout HD recordings in SD through the firwire unlike the JVC.
Cheers
Tim
Tim Ward is offline   Reply With Quote
Old April 18th, 2006, 07:51 AM   #18
Images: 1
...play HD out of the JVC through the component connectors in SD and record in on a Sony DSR45 to DVCAM.
Tim,
That is where you are losing some of your ability to keep the color looking like digibeta. DVCAM is the same 4:1:1 color space and 5:1 compression as mini-dv. If you could get a HD capture card that downconverts to an SD codec such as DVCPRO50, you might not be able to discern the difference without very close examination.
-gb-
Old April 18th, 2006, 09:04 AM   #19
Greg,
I see what you mean though I am using PAL so it's 4:2:0 as compared to Digibeta/DVCPRO50/D9 4:2:2. But then again HDV is also 4:2:0 (in Europe as is DVD/DVB etc) and this is why I said apart from the richness in colour the look of HDV (the JVC anyway) downconverted to SD is close to Digibeta. Surely, if the HDV codec is 4:2:0 then an expensive capture card will show very little difference?
HDV is also much more compressed than DV/DVCAM, I can't remember the excact figure but I think it's something like 14:1 compared to Beta SX which also uses MPEG II which is 9:1 at 18Mbs. This is far more than DVCAM at 5.1 at 25 Mbs so I won't loose due to the DVCAM compression ratio, although it could add artifacts due to re-encoding.
Cheers
Tim
Old May 7th, 2006, 09:24 AM   #20
Another New Boot with a dead pixel
Hi everyone!
Im new to the forums although I've been silent particpant for a while. I just recieved my HD100 am already in love with it. NO SSE WHATSOEVER. But, there is a nice white dead/stuck pixel in the lower left side of the image. Its on the flip out monitor and shows up after I dump the footage on to my mac. It shows up even at 0 gain. I am working on a shoot this week, so if anyone could shoot me an email at variable_101@hotmail.com and send instructions for the "service menu fix" I would greatly appreciate it. Thanks, and I am glad to be here; the people here are great!
Alan Ortiz is offline   Reply With Quote
Old May 7th, 2006, 02:49 PM   #21
Yup, much to my horror I discovered a dead CCD pixel on my new HD100.. thankfully I saw this post and feel a little more relieved. I've emailed Steven Thomas for the info. Thanks.
Webb Pickersgill
Bassline Digital, LLC
Webb Pickersgill is offline   Reply With Quote
Old May 7th, 2006, 06:01 PM   #22
Just to report back concerning my dead pixel issue. The service menu fixed it, although I had to do it twice because the first time cured the original dead pixel but a new curiously appeared!
However, last week a colleague and I did some HD tests on a beach with clear sunny skies, comparing the HD100 with the Z1. I was playing around with the manual iris setting on the lens. I shot 30 secs or so with the iris just open. The CCDs were by now were quite warm. When I got back and played the footage back downconverted to SD on a grade one monitor through component, I saw a very faint SSE. I have read on this forum before that this may well still be evident under certain conditions so I put it down to that and not unduly worried, just yet! But I would be interested to know if JVC UK/Europe have a similar policy of upgrading like JVS US has done for this same SSE issue.
Tim
Old May 7th, 2006, 07:28 PM   #23
Just a few notes..
The JVC upgrade does not fix the SSE issue, you must send it in to JVC to get calibrated.
Also, before you map pixels out, you need to let your camera warm up. I left mine on for about 40 minutes before mapping.
Old May 7th, 2006, 09:56 PM   #24
thanks!
thanks for the email with the instructions! I shot quite a bit today and have not noticed the dead pixel in any of the footage- yet. Im using a different scene file- Tim Dashwoods CineWide, so im not certain if this has an impact at all or not. All I have to say is that I am LOVING what is coming out.
Old May 8th, 2006, 08:25 AM   #25
JVC Regional Sales Engineer
Right, Steven. The update to revision A does not have any effect on what people call SSE. New manufacturing techniques have taken care of that. If it is detected, we would like to take care of that for any US owner.
By the way, if anyone does send in a camera to have SSE addressed, be sure to indicate exactly the camera settings under which you saw it. Such as frame rate, gain settings, iris setting, and any coloration if noiticed. It matters.
It looks like all who need the pixel blemish proceedure on this thread have it. If any one needs it, I am at kfreed@jvc.com
And yes the camera should be warm. The blemish must be a certain brightness (really electronic level) for the software to detect it. And blemishes do get brighter as the camera warms. Put a blanket over it and let it warm up. We do not recommend placing the camera in a microwave oven however. That would be a bad thing.
Ken Freed
JVC Mid-Atlantic District Sales Manager
(201) 637-7706
kfreed@jvc.com
Ken Freed JVC is offline   Reply With Quote
Old May 8th, 2006, 09:18 AM   #26
Thanks, Ken... I'm sure that JVC doesn't recommend slow-roasting an HD100 over an open fire, as Andy Young did in Madagascar (just because it worked for him, doesn't mean it'll work for everybody -- but if you're going to do it I'd suggest charcoal over propane any day).
Old May 8th, 2006, 10:54 AM   #27
Somehow I feel this would void the warranty :)
Old May 10th, 2006, 10:44 AM   #28
I also have a dead pixel
Hi Everyone,
I'm a newbie to the forum, but so far its been a great source of info. I found this thread related to the dead pixel problem. I just received my HD100 and within 20 minutes of use, I got a white hot pixel in the upper right corner of the screen. If anyone can get me instructions on how to fix that via the service menu, I would appreciate it. craig@alwaysbetterproductions.com Thanks very much.
- Craig
Craig Roblewsky is offline   Reply With Quote
Old May 10th, 2006, 11:29 AM   #29
Got the instructions
Right after I posted that last message, Ken Freed sent me the instructions. Thanks.
- Craig
Old May 10th, 2006, 11:39 AM   #30
Dead pixel
Hi Everyone,
Pictures do not do justice to this beautiful looking camera.
I just received my HD101E and within few minutes of use, I got a white hot pixel in the down-left corner of the screen. If anyone can get me instructions on how to fix that via the service menu, I would appreciate it.
Thank you very much.
Johnnie
Johnnie Behiri is offline   Reply
