JVC101E-onboard mic at DVinfo.net
Old April 11th, 2006, 07:43 AM   #1
JVC101E-onboard mic
hi
Used the XL1s onborad mic for a wedding, (for everything)it was fine, doing a wedding with tyhe JVC101e and was wondering if the mic would be as good as the mic on the xl1s,the xl1s mic is a stero mic, i don not know what type of mic the jvc101e has.
j
John Doran is offline   Reply With Quote
Old April 11th, 2006, 08:54 AM   #2
Originally Posted by John Doran
hi
Hi John.
I don't know the XL1S but the stock mic on the HD100 is terrible. If you want an inexpensive mic that sounds great get a RODE NTG1 (mono), connect it to Input 2 on the camera and set the switch to "Channel 2 to Channel 1" for recoding on both channels at the same time. I think I got mine at B&H for about $250.00, including holder and a short cable.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old April 11th, 2006, 09:01 AM   #3
mic
thankyou very much, i will have a look at that
john
Old April 11th, 2006, 09:19 AM   #4
Well, it is terrible, but so was the XL1s mic in my opinion. Better go for the rode, or bvetter yet, a sound man with a mic very far from the camcorder (and preferrably close to the subject :-) )
Werner Wesp is offline   Reply With Quote
Old April 11th, 2006, 09:37 AM   #5
mic
hi werner
i am a oneman band, the xl1s mic was ok it was stereo, it's just i have not tried the 101e's mic yet, if it is roughly the same as the xl1s' it will do.
john.
Old April 11th, 2006, 09:51 AM   #6
Contributor
hi werner
john.
John I'd back up the comments about the nTG1 but if you can afford it you might consider a second mic - radio the Senheisser Evolution 100 series (quite cost effective) for the other channel. Should get you even closer to the action with a little planning.
John Mitchell is offline   Reply With Quote
Old April 11th, 2006, 01:57 PM   #7
mic
thanks again
but is the onboard mic that bad, i will probaly go for the rode.
john
Old April 11th, 2006, 02:36 PM   #8
Correct me if I'm wrong, but the "Ch-2 input" switch is for routing input 1 to record on either just ch1 or to both ch1 and ch2. It will not route the signal from input2 to both channels, in fact if switched to "input 2" it will mute input 2 entirely, in favour of input 1
Paul Jefferies is offline   Reply With Quote
Old April 11th, 2006, 02:47 PM   #9
Brain fart on my side, that's what I meant :) Connect the mic to Ch 1 and use the switch to record on both channels.
Demo Reel
Old April 15th, 2006, 07:13 AM   #10
The JVC onboard mic is pretty bad. It really has a sharp roll off on the bottom end.
I swapped it for one of our Sony mics from a DXC637 and it's noticibly better for Nat Sound.
I haven't tried the NTG1. It is substantially longer than the stock mic at 8.5 inches. Does it fit well in the mount?
What about a mic like the Sony ECM-NV1? It's a similar price...OEM from the PD170 and made for camera mounting.
Dave Beaty is offline   Reply With Quote
Old April 15th, 2006, 08:11 AM   #11
Images: 5
I also use the mics. from my DSR-300a. Waaaay better than the JVC's mic.
Laszlo
Laszlo Horvath is offline   Reply With Quote
Old April 15th, 2006, 11:10 AM   #12
Yes, it does. I bought mine with a shock mount that connect to the shoe connector of the camera. I like it in the center instead of being on the side. In fact I removed the standard microphone mount.
Demo Reel
Old April 16th, 2006, 03:00 PM   #13
So where would you put the "light" if the mic is in the middle ?.
john
Old April 16th, 2006, 05:33 PM   #14
Well, I guess that in that case you would use the side holder for the mic, it works fine for the NTG1. I don't use any on-board light. Besides, taking the holder on or off is just a minute.
Demo Reel
