jvc101e at DVinfo.net
Old April 4th, 2006, 04:40 AM   #1
jvc101e
just got a pal 101e, and not sure about the menu settings for the dv, could someone enlighten me as to the settings for recording dv pal. please
thanks .
john
John Doran is offline   Reply With Quote
Old April 4th, 2006, 05:42 AM   #2
jvc
help would be appreciated.
john
Old April 4th, 2006, 05:49 AM   #3
Hi John,
Assuming you want DV PAL, Go to the "video format" menu, set "frame rate" to 50/25, then set "Rec" to either DV-25P for progressive or DV-50i for interlace
Paul Jefferies is offline   Reply With Quote
Old April 4th, 2006, 09:17 AM   #4
thankyou very much
quote:
"Assuming you want DV PAL, Go to the "video format" menu, set "frame rate" to 50/25, then set "Rec" to either DV-25P for progressive or DV-50i for interlace"
what would be ok for weddings:---- DV-25P for progressive or DV-50i for interlace"
is there any other settings i should change
i cannot scroll up and down in the :
file
full auto off
gain
shutter
etc......... menu.
how do i do this please.
john
Old April 5th, 2006, 03:50 AM   #5
Hi John,
I don't know why you cannot access this menu - I have not had that problem. As to shooting progressive or interlace on wedding videos, that would be a personal choice - I shoot everything progressive, but not everyone likes the look of progressive, so do a few tests and see which one you prefer,
Paul J
Old April 5th, 2006, 04:15 AM   #6
101e
thanks
I have just changed from the XL1s to the 101e, bit of a learning curve, the xl1s was, (only) interlace right
john.
Old April 5th, 2006, 05:27 AM   #7
john.
The XL1s had "FRAME" mode that was similar to progressive but lost a little resolution in achieving it and so wasn't as good.
I just shot a project using an HD101 and XL1 as backup. The difference in quality is night and day! The JVC is a great camera but has a bit of a learning curve in order to get the best out of it. I'd use the info on this board together with your own tests in order to find the best settings for your tastes. Allow a day or two of toying and trail and error until you get it spot on.
Mike Marriage is offline   Reply With Quote
Old April 5th, 2006, 05:48 AM   #8
101e
thankyou very much.
was looking for the settings..ie frame rate etc to be similar to the xl1s when i was shooting it in dv.
john
