#16 |
Thanks Barry.
Detail setting is a question that gets asked alot around here, so I think I'll make this a sticky.
Tim Dashwood |
#17 | |
#18 |
I think it was Nate Weaver that intially said that the smaller the screen the more detail the bigger the less detail. I agree with this in my findings as well. For instance, if the intended delivery is SD-DVD I think you can safely go into the + ranges to get the image to be more detailed on the smaller screen (without much penalty). However, on a 51" HDTV you'll want the detail lower (I selected -7) because the edge enhancement is more apparent. The bigger the screen the lower detail should be set.
#19 | |
Earl R. Thurston, Stargate Connections Inc. Made with GY-HD100: The Container Adventures: The Rescue |
#20 |
If you look at Tim Dashwood's resolution charts in the thread about the 13x, youll see that turning the detail from off to min:high:high is a pretty huge difference in my opinion. I think on the min setting it gives you a significantly sharper picture but doesnt look like too much artificial sharpness. But off is just too soft.
#21 | |
The only time that I add sharpening to still photos is when I post things on ebay and I am limited to their 400x400 image size. For the lower resolution, sharpening really helps the picture look sharp. If you do the same on a larger image it looks terrible. |
#22 | |
I didn't see the screening, but if I remember correctly, one of Andrew's regrets regarding the film transfer of his documentary shot on the HD100 was that his settings were pretty much set to default given his last minute use of the camera. Specifically that it may have looked better on the big screen had he dialed the detail down. |
#23 |
Between -3 and -6
I find from my tests that under -6 the image starts to look too soft for me. I would never use "MIN" that's way too soft for me. Above -3 it's starting to look too "video sharp." I adjust according to envorinment, i.e. outdoors on a sunlit day go -6, indoors in a fluorescent lit room I'd probabaly dial it up to -3, tungsten lit interior I'd probabaly go to -4 or -5. The lens iris setting makes a subtle difference in overall sense of sharpness not just DOF.
#24 |
Ya, I agree those settings in detail are very similar to what I use, but I prefer -4 for outdoor shots.
#25 | |
suspected JVC target
Judging from the design of the camera itself, location of controls, & over all functionality, I think JVC is not only targeting those of us shooting for a film-esque look, but also a big target is TV stations around the country. A multiformat, rugged, familiar camera at a great price & that uses tapes that don't cost $80ea. is very attractive to TV stations who are also having to invest $100,000s to outfit their facilities with HD to comply with the upcoming FCC mandated broadcast SD retirement. Imagine: a thousand stations who need as many as 40 new cameras!!!! The enhanced detail will probably be more appreciated by station news crews & in-house production. |
#26 |
FCC is not mandating an end to standard def. They are mandating an end to analog broadcasting. It is possible to broadcast SD over ATSC, and it is an option for many stations to simply slap an analog to digital converter on the signal chain just before the transmitter to remain legal. Well, they still have to buy a new transmitter, but they don't have to retool the whole station for HD.
#27 |
between -7 and min.
I agree with all the gurus on -7 and min.
i ran a test and find that only these are acceptable. min is a bit soft on edges, i used virtualdub to sharpen it at 30 or 40 the overall is much more beter on SD TV. not yet know to HDTV, i have no $$ to buy. but aliasing is also a problem and some artifacts will enhanc along with it. to me the edge enhancement is max at -7, anything beyond that is too much. if i have a HD TV and possibly or35mm blow up i will let u know more but likely put it at between min and - 7 is best as a range personally i will put -7 or even -5 for SD broadcasting. and for film and 35mm i will use min. when i need to sharpen can get a much apealing on SD. time is issue if u r running on slow pc JY |
#28 | |
You're right
I also didn't put in the background, anecdotal as it may be, basis for my statement. Many stations, at least in top 60 markets, if they are wanting to be "power players" in their markets are going to switch over to full HD local broadcast. At least that's what the chief engineer at the station where I work tells me. Our station is going to be full HD by 2008 I think...I can't remember exactly...that's if all the budgeted stuff happens. Anyway, back to the point. IMO a broadcast station would prefer settings on the JVC camera to be everything that the "cinema" people hate and there's probably an opportunity for JVC to sell a lot more cameras intended to create broadcast content than cinema content. That's what I was trying to say. |
#29 | |
#30 |
Off
The lifespan and workflow is important to consider before using in-camera effects. Personally, it makes sense to me to preserve every ounce of information if you are recording on tape as opposed to SDI out. It doesn't matter what the effect is, if you are using any effect it means you are recording less information on the tape. Most people wouldn't consider edge enhancement an effect, but think of it this way: if you record with detail at OFF, you can add it in post. If you record with edge enhancement at MIN, you CAN'T remove it after-the-fact. If you record at OFF and you find that you ALWAYS add it back in during post, then, what the heck, record at -7 to MIN and save yourself the rendering time.
If you are transferring to film, I'd recommend OFF. Film, after all, has no edge enhancement. This is, however, educated guesswork on my part since I won't see any of my footage on film for another month or so.
http://www.fashionerfilms.com |
