HD100 Series Scene File Recipes & Downloadable .SCN files - Page 7 at DVinfo.net
Old December 19th, 2006, 12:15 PM   #91
Originally Posted by Rati Oneli
Hi, I was inputting Paolo's recipe into my HD100 the other day and notices that it didn't speicy some settings like: v/h balance, H Frequency, V Frequency, white paint. Should I worry about it? What should be the settings? I also looked at other recipes and they don't specify these either. Thanks.
Hi Rati. No I don't change the defaults for those settings.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old December 19th, 2006, 12:21 PM   #92
Originally Posted by Daniel Patton
. Thanks for the head start Paolo!
You're very welcome.
Gamma = Standard
Not sure exactly how this helped
Just an overall observation via the WFM seemed to me to lead to a more balanced gamma. TrueColor tries to achieve both accurate color rendition and maximum latitude. BTW, the emphasis in TrueColor is on skin tones so that explains the red levels as red+yellow are the main components of skin tones. While I think that the red level is where it's supposed to be in the VScope, it could be that it's not the optimal for GS work. It would be interesting to see how it works with a blue screen.
Take care.
Demo Reel
Old December 19th, 2006, 07:09 PM   #93
@ Paolo
I used your TcV3 in a short film I made this year. Worked really nice. Credited you in the film.
Cheers,
Jon Jaschob
http://www.fotgfilms.com/OnceUponATimeInTheCampsite
Jon Jaschob is offline   Reply With Quote
Old December 20th, 2006, 09:46 AM   #94
Thank you Jon.
Demo Reel
Old January 17th, 2007, 08:35 PM   #95
Stephen Noe's - Zipped .SCN Files
Is anybody else having trouble downloading the zipped .scn files for "dark interior"?
Best,
Tommy
Tommy Davis is offline   Reply With Quote
Old January 19th, 2007, 05:30 PM   #96
Originally Posted by Tommy Davis
So I need to load the Scn files onto an 3rd party SD card reader ?
Yes, you need an SD card reader in order to move scene files.
Can anyone suggest a card reader?
It makes absolutely no difference which one you choose, as long as it's compatible with Secure Digital flash memory cards.
Old March 14th, 2007, 04:43 AM   #97
Christopher Doyle
I've read a few interviews with the Austrailian/Asian cinematographer Christopher Doyle recently (having watched a batch of the excellent films he's been involved with).
On 'The days of being wild' (Wong Kar-Wai) he talked of using 4/5 filters for certain scenes. Would this kind of technique be necessary with the HD digital video camera's? I can see why we would use ND filters etc but having scene file manipulation within such camera's would this still be relevant?
Part of the reason I've posted this is because I want to try and achieve a similar look to his films...that green hue but with 'violent' reds:
The film 'Dumpling' is a good example (the colours to me appear to be a more aggressive 'Amelie' setting)
http://www.filmmakermagazine.com/fal...ges/doyle1.jpg
2046 another example:
http://filmbrain.typepad.com/filmbra...s/2046_wkw.jpg
Slightly off the topic...I've recently used Paulo's tru colour 3 setting for a corporate video - this worked really well (thanks Paulo). Mostly shot as exteriors - if I were to carry on shooting for the same project but indoors (in say a darker exterior) would I need to make any alterations to this setting...use another setting perhaps (but still matching the 'look' of the exterior shots)?
Cheers.
David Scattergood is offline   Reply With Quote
Old March 18th, 2007, 06:59 PM   #98
I have a question about Paolo's True Colour settings. Does V3 render V2 totally obsolete or there are still situations where V2 or even V1 would be recommended over V3?
Does V2 have a wider dynamic range or something? Would any of them be recommended to shot a low key lit with lots of shadows night shoot show?
Michael Maier is offline   Reply With Quote
Old March 18th, 2007, 07:35 PM   #99
Why do we use these scene files? Can't we have these effects in post with After Effects or something?
Erhan Gucel is offline   Reply With Quote
Old March 18th, 2007, 07:43 PM   #100
Yes... but using the on-board processor BEFORE the mpeg2 compression or downsampling is applied can give you more range of control.
If you are capturing with an uncompressed card, then definitely attempt to optimize the maximum latitude possible for your scene and manipulate the image in post.
Tim Dashwood
Old March 18th, 2007, 09:53 PM   #101
Version 3 is an improvement from V2 so I encourage you to use the newest version.
Demo Reel
Old March 18th, 2007, 09:56 PM   #102
It depends, TrueColor is meant to make the work in post easier and more precise. It's also intended to give you the widest latitude with your camera. If you crush your blacks because of a uncalibrated camera, there is no amount of post that you can do.
I am against using "camera looks" with digital cameras except in specific cases, the use of a scene file is meant, in my workflow, as a tool to keep the camera calibrated to the widest latitude and to the most neutral settings. If you think that that would be the default from the factory, well,m think again :)
DSC made a whole business based on the fact that cameras usually come out of the factory un-calibrated.
Demo Reel
Old March 19th, 2007, 02:56 AM   #103
Thanks Paolo.
So it seems TrueColor is much like the so called “digital negative” way of shooting that F900 DPs talk about.. You use it to get the cleanest image possible and work on it in post to achieve the look you want. That’s basically what most DPs shooting the F900 for narrative do. Get the cleanest and widest latitude possible and work on it in post. Good stuff.
Isn’t that what TrueColor is made for anyways? At least according to Paolo.
About capturing uncompressed, judging by Taylor’s experiences posted on this boards and his ShowReel article, it seems in the case of the HD100 and the component out, there isn’t much advantage in capturing uncompressed really. Maybe with the HD250 and SDI, but with the analog component doesn’t seem to be worth the trouble or expense. The results Taylor got in post when manipulating the HDV signal was amazing. I don't remember exactly now, but I think Taylor even used TrueColor, didn't he?
Old March 19th, 2007, 08:48 AM   #104
Yes, regardless the camera, the F900 is very high-end but the same is valid for all digital camera, your latitude is currently more limited than with film. By avoiding creating a bias in the digital negative, and by carefully calibrating the camera, you obtain the most complete digital signal that the
camera can give you. When you bring that signal inside your compositing/NLE suite you can use the massive processing power and precision of modern computers to do the kind of manipulation that you need and you have the advantage of the "Undo" function. Also, things like stacking copies of the same clip using the blend mode are not achievable in camera.
That's exactly the reason for it.
Actually I disagree on that. It's not always needed, one size deosn't fit all :), but the use of 4:2:2 instead of 4:2:0 has advantages. Background noise is one of the biggest problems of HDV compression and uncompressed component out addresses that.
Demo Reel
Old March 19th, 2007, 09:30 AM   #105
What do you mean?
