Multi Camera Control HD-100U (Jam Sync) at DVinfo.net
Old February 13th, 2006, 03:17 PM   #1
Does anyone know of a firewire box like control device that can send a command to the JVC HD-100U camera to start and stop recording?
Looking for a single device that can start and stop 3 cameras at the same time...any comments would be greatful. thanks.
Rob Stiff is offline   Reply With Quote
Old February 13th, 2006, 07:06 PM   #2
I don't know of a firewire device.
However, maybe some clever engineer could create a wired remote for the trigger on the remote zoom port (on bottom of lens.) There is a schematic in the lens user guide. It looks like only 2 pins control the VTR on/off.
Tim Dashwood
Old February 14th, 2006, 03:21 PM   #3
Hi Rob,
What is the distance you need between the camera's?
I'm working on a device which has more features, but I could strip it down to do just that. It will use inexpensive Cat5 cable to connect between the the camera's (no ethernet protocol, I use the twisted wires).
In theory 100 meters (300 meters) will be possible between the camera's.
What is the time-frame you need it?
How do you want to operate?
Use one of the camera's as the Master?
The control I'm currently making will make all the camera's slave.
An external Start/Stop button triggered manually by a button (or by USB would be possible afterwards).
Marc Colemont is offline   Reply With Quote
Old February 24th, 2006, 10:04 PM   #4
I'll pay for the VTR system
Marc, I'll be your first customer to get three cameras to
sync as best as possible with some device.
Old February 25th, 2006, 07:43 PM   #5
Please let me know if there is interest for it.
OK, Here are the specs I'm working on:
HDV-remote Receiver:
- Start/Stop control
- High Quality Composite Video transmitter for Cat5 cable
- Manual Iris control Input
- (future) Intercom RTS/ClearCom compatible option.
- Fujinon cable which connects to the lens, RJ45 XLR to the control unit.
- No external power required.
HDV-Remote control:
- upto 4 cameras can be simultaineoulsy sync controlled for Start/Stop
- Manual Iris control for each individual camera with precision potentiometers
- 4 High quality Cat5 Composite Video receiver inputs
- 4 Composite outputs to be able to view the camera video outputs at the control side.
- (future) Intercom base station option.
- 110/220V AC/DC adapter required.
The connection between the HDV-remote and control is done with a Cat5 cable. The connections are using the XLR RJ45 connectors. This way either inexpensive Cat5 cable can be used or professional high flexible Cat5 cables with durable XLR Cat5 Neutrix connector.
100 meters (300 feet) minimum reliable distance between the remote(s) and control is my goal.
I could also make a version with only Start/Stop and Component video on the Cat5. But then the future Intercom upgrade and Iris control will not be possible at that moment.
A DV remote control version with LANC procotol is also in the pipeline with PC control.
Let me know if there is an interest for one these devices, then I start prototyping the one which is requested the most.
Old February 26th, 2006, 12:25 PM   #6
Ok, How Much?
I like this option:
HDV-Remote control:
Name your price?
Old February 27th, 2006, 04:37 AM   #7
Hi Rob,
I'm working on the schematics now. As soon as I'm testing the PCB in a few weeks then I know the components for sure. The most tests will go in the twisted pair video receiver circuit, tests with long Cat5 cable. So the next weeks I will have no news until the tests are done to calculate the price.
I'm also thinking of adding a selector output. This way you can easily switch between the 4 cameras, and check the values on one monitor or waveform/vectorscope.
I'll make sure the price is affordable. I will also make an introduction price for the first buyers.
Old March 13th, 2006, 08:58 PM   #8
Three Camera Controller
Robert,
Have you seen this three camera contoller by Grizzly Pro?
http://www.grizzlypro.com/r3.htm
To quote their description "The r-THREE system combines the functions of Pan/Tilt/Zoom, Camera controls and Video feed for up to three remote cameras into an easily portable and compact solution."
Only one cable for each camera. Up to 600'.
I haven't used one, but it sounds very interesting.
Hope this helps,
Ian
Ian Semmens is offline   Reply With Quote
Old March 14th, 2006, 07:08 AM   #9
I've seen it working at NAB last year.
It's cool, but it's designed for DV cameras and works on LANC.
The video circuit was not that crisp. Which is needed for HD
Old March 14th, 2006, 11:15 AM   #10
I've almost got my 3 camera remote finished. The box is built, the LEDs, RJ-45 jacks and switches are mounted, I purchased the 8-pin plugs from Fuji (via my JVC dealer,) and now I just need to create the 8-pin to RJ-45 adapters.
I'll post pictures soon.
Tim Dashwood
Tim Dashwood is offline   Reply
