HD100 tested beside 35mm on set of '24' - Page 2 at DVinfo.net
Old January 19th, 2006, 01:30 AM   #16
Originally Posted by Joel Aaron
Taylor, thanks for the great info. You sold me on Showreel - I know first hand that advertising runs most U.S. media.
The showreel article really highlighted the 35mm adapter units may be critical for dramatic TV so I'm sure a lot of us are curious to hear an unbiased comparison.
I'd love to hear resolution differences between the Mini35, Guerilla35 and Micro 35. Maximum usable lens F-Stop (ie deepest usabable DOF) on each unit would be interesting. Vignetting issues and actual Field of View differences would be good to know also. If one unit requires more of a zoom to get rid of vignetting then you'd be losing FOV...right?
And if these units seem soft can they be sharpened up in post enough to get the job done?
Thanks for contributing!
I've used the HD100/Mini35 combo on 2 jobs now. I find that the groundglass is a little too visible at HD resolutions (which isn't the end of the world), but HDV doesn't deal with all the grain very well...it's too hard to compress cleanly.
Not to mention that the HD100/Mini using Cinegamma is 64 ASA, on a good day. One gaffer thought it was closer to 32. In my low budget world, that makes me only want to use it for daylight exteriors.
I love it, but I'm not sure how practical it is anymore, like I once did.
My Work: nateweaver.net
Old January 19th, 2006, 01:33 AM   #17
Hi Taylor,
Thanx for all you work in getting information out there. I’m sure you’ll be getting lots of replies to your request for info on how to procced with your tests; there’s lots of people out there trying the same thing. So I'll keep my reply short as possible.
We’re in pre pro for a feature that we hope to shoot using the two GY 100 we have, both fitted with the P & S mini 35. We are by passing the tape transport and thus the poor quality Mpeg 2 compression and shooting straight to disk using two Waffian HR-1 recorders and CineForm’s excellent HD Prospect compression as an intermediate. I say hope because there are plenty of issues as yet unresolved. The biggest are:
1) Noise from the CCD
2) Barely acceptable HDV resolution at 720p
3) Poor quality of the relay lens supplied with the mini 35
4) Focus concerns
1) CCD noise. In all areas of the image below a middle to light grey there is a very noticeable pixel dance. It is especially noticeable over lighting gradients on areas of flat colour. Mildly underexposed skin tones have a blotchy look that can resemble great big birth marks. At times it looks like the bit depth of the colour sampling is too low even though we are capturing a 10 bit image straight to disk. My guess here is that the pixel size of an HDV 1/3 inch CCD chip is just physically too small. It is probably something to do with the wavelength of light being similar in size to a single pixel or perhaps the number of individual photons needed to excite the pixel to output each luminance and colour value. My (garden shed) theory is that since a pixel from a 1/3 inch CCD is 1/4 of the size of a pixel from a 2/3 inch CCD it will be hit by a quarter of the number of photons. Perhaps this number of photons is small enough that the essentially random nature of photon strikes becomes statistically significant. Sort of like the difference between doing market research on a group of 25 people or a group of 100 people. Let me re-emphasize that I am just guessing here.
2) Resolution. I’m just not convinced that 720p is really HD. Shooting with detail off gives an unacceptably soft image so we have to resort to the artificial sharpening of a detail function. With that comes all the associated issues such as increased noise and ghosting, issues which are really only noticeable under close inspection but which non-the-less I’m sure contribute to giving that ‘video’ feel.
3) Mini 35 Relay lens. Over all the new mini 35 is a superbly well engineered piece of kit and so it baffles me as to why they would use such a crap piece of glass in their relay lens. I have run resolution test which show an enormous difference between using the lens wide open and stopped down by just one stop. There is a very noticeable colour shift and a foggy softness when wide open that largely disappears at one stop closed. Added to this the are the horrible blue colour aberrations which are present on all strong highlights. These do diminish as the relay lens is stopped down but they are still visible at about 5 stops. Before you do anything with the mini 35 take the relay lens in your hand and have a look at how much glass there is there. It just doesn’t look like enough. I'll be posting some of my test results on a blog that has been set up: www.indiefilmlive.blogspot.com. Let me know if the link doesn't work.
4) Focus. You lose about 2 stops of light using a min 35. Some people say 1.5 but I’m not convinced. It is actually very hard to tell as the Fujinon lens diaphragm seems to be particularly badly calibrated. I read somewhere that the relay lens is only T2.8ish which makes me think that with the ground glass effect added a 1.5 stop loss is impossible. Anyway, you lose light so you have to shoot about 2 stops more open than you usually would, or if you prefer, shooting with 100 ISO stock. Add to that the fact that the relay lens has to be shut down by at least one stop and you might actually be down to 50 ISO. This means you need to shoot high speed primes mostly wide open. Which means you need a really good focus puller. And now remember that the eye piece view finder is basically useless for anything other than operating. How do you judge such critical sharps other than off the ring? There is an answer somewhere but it involves buying some sort of expensive high deff monitor for the operator.
We recently saw our first 35mm test blow ups and were all suitably unimpressed. It could have been a poor projector lens and it could have been the blow up process we used (‘LARA’, a south African invention as far as I understand where each frame is grabbed individually of a very high definition monitor). Later this week we hope to be going for a Lighting blow up to be able to compare.
There is also quite a good discussion about it the mini 35 and other aspects here - http://www.dvinfo.net/conf/showthrea...t=56502&page=2
I hope this helps.
Cheers,
Joe de Kadt. DoP.
Joe de Kadt is offline   Reply With Quote
Old January 19th, 2006, 05:02 AM   #18
Have you tried the other alternatives, which claim to lose much less light than the Mini35 like the letus35 and the G35? If the problem is only light, these might help somehow. Do you feel the resolution or sharpness is considerably knocked down in comparison to the stock Fujinon?
Michael Maier is offline   Reply With Quote
Old January 19th, 2006, 05:28 AM   #19
Joe, very interesting post. Thanks for sharing.
But you should remember you can only expect so much from a $5,500 camera. Sure it isn't Varicam or F900, which by your complains, it seems you might barely be happy even with them, but remember those cameras cost over 15 times the price of the HD100 after they are all ready to shoot the way the HD100 comes out of the box. When you throw an image converter in the equation, it can only “improve” the image as much, before it's trade offs (in this case, in exchange for shallow DOF) start to get in the way. I have been thinking lately if the whole 35mm adapter thing is really worth all the trouble or if having a shorter DOF in close ups only, but an overall sharper and cleaner image is the best way to go with those 1/3” cameras. I’m pretty sure that using a Mini35 in a movie you intend to blow up to 35mm and project is suicide. To be honest, I have my doubts if even a F900 with the Pro35 wouldn’t be suicide. Have you noticed that none of the commercially released movies shot on the F900 used the Pro35? Instead, they used Fujinon HD primes or Zeis Digi Primes for the best sharpness possible. What does that tell you?
I have got to the conclusion after long considering to buy a 35mm adapter, that an image converter is a compromise and it should be expected. Hoping for something else is unrealistic. That may be subjective, but one thing is for sure, a $5,500 with an image converter won't hold up against a F900. Big old saying of " You get what you pay for" plays a big role here. I didn’t completely rule out buying a 35mm adapter yet, but I’m not expecting it to improve my image as much as I was a while ago, and sure not expecting it hold up on a 35mm blow up.
Have you considered renting a F900 for your shot? You may be much happier than trying to squeeze F900 performance out a 1/3" camera.
I have a HD100 and love it, but I know it can't get even close to be a camera made for 35mm blow up, neither can any of the 1/3” HD cameras. I would be surprised if they could even match Super-16 blown up to 35mm. If you throw in a Mini35, I think even normal 16mm would look sharper. Just my opinion.
P.S. I'm following all your tests and results very closely. It's all very interesting.
Old January 19th, 2006, 06:22 AM   #20
4) Focus concerns
How about abandoning the mini35 in favor of the 13x fuji lens?
Stephen L. Noe is offline   Reply With Quote
Old January 19th, 2006, 10:52 PM   #21
That kinda makes me wonder if the HVX would be a better match when using a 35mm adapter. Also, I've seen you comment you don't really want to sell your JVC after seeing how well it did against the HVX. Is it possible to dial in the HVX to be more JVC like or is the JVC just capturing something different than the HVX that you like better?
To me the footage I've seen from that lens looks very sharp but it doesn't really get you any closer to the 35mm DOF feel. Out of the box the footage still looks very video-ish to me on all these cameras including the F900.
What about this variation - get a JVC to Nikon mount adapter, throw a Nikon 28mm or 20mm lens on there (with the multiplier becomes telephoto) and then put a G35 or Micro35 in front of that? The Nikon becomes the relay lens and it's a lot less expensive than a Mini35.
Joel Aaron is offline   Reply With Quote
Old January 20th, 2006, 04:30 AM   #22
Back in 2001 i made a film using a PD150 and a 35mm adapter with prime lenses and i can tell you this is something i'll never do again. We had major problems from vignetting, and rotating ground glass in the footage. Low light was bad and grainy and we ended up lighting everything like we were using 35mm cameras. Overall the experience was bad and large portions of the footage couldn't be used.
As much as i like the 35mm DOF, it not worth compromising your film for it, instead concentrate on storytelling.
Tony Balogun is offline   Reply With Quote
Old January 20th, 2006, 10:18 AM   #23
Was it the P&S Mini35 or something else?
I think you're right that focus needs to be the story. Before I shoot anything longer form I'm going to have my solution well tested. If 35mm adapters won't get me there then I won't use one.
Old January 20th, 2006, 10:33 AM   #24
Joel,
Don't let my experience put you off, back in 2000/01 i believe the mini35 was the only adapter available, it was the pioneer of the products available today. Over the technology has improved and people are getting better results... and yet judging by footage from the JVC and Canon it seems that the extra resolution is bringing those old problems we experienced back.
I'm currently evaluating two low budget feature films made with the Sony F700 and F900, and the cinematography is fantastic without the 35mm adapters, in fact for both films it's the story that lets them down.
I'm looking at purchasing the Sony HD XDCAM for a project later on this year, i'm hoping the problems will be resolved by then, even so i still may not use one.
Old January 23rd, 2006, 05:29 PM   #25
What defines 'good cinematography' ?
Joel,
As far as I know, there are only two P+S adapters available. The Mini35 for 1/3inch CCD cameras and the Pro35 for 2/3inch CCD cameras. The pdf brouchure for the upcoming Sony XDCAM was a slight letdown when I saw the 1/2inch CCD spec, as I was kinda giddy at the idea of popping on a DigiPrime onto a HDV-esque camera + 2/3inch imager. (HDV is good for what it is, IMOP). That said, I am a bit unclear what it was about the f700/f900 that enticed you: Since you were referencing 35mm Cine adapters, I'm wondering if the f900 films your were looking at used DigiPrimes shot wide open, in which case you would which is capable of acheiving DOF that can come into the realm of 35mm DOF. And given no cine adapter whose elements will certainly decrease some of your resolution, I can see how you may have been looking at some good cinematography. Or maybe the movie you were evaluating was shot by a good DP, but then again, make sure you look at a movie shot well with a cine adapter so you have a good frame of reference to make a judgment call.
Most importantly, before you buy anything, my advice would be to decide what things you find as nice cinematography because not that the XDCAM could not do nice things, but a 1/2inch CCD might be a hindrence to what you are ultimately looking to acheive, ie 35mm DOF w/out adapters. If I think 1/2 inch, I think about the camera far away from the subject, wide open, and at the very end of the barrel if I want shallow DOF. Where do you want to make the tradeoff?
On a related note, I want to see the 2/3inch GV Infinity/DigiPrime combo. Some call it a 'newscamera' but I've shot narrative on interlaced newscameras and it looked fine. Funny that they used to shoot news with 16mm film.
As cliche as it sounds, I look at camera/lens/CCD/cine adapter/film all as items that can not exceed the qualifications of the person using it, or that can excel because someone qualified is using it.
Taylor Wigton
DP, Los Angeles
Taylor Wigton is offline   Reply With Quote
Old January 24th, 2006, 04:46 AM   #26
Taylor,
You're correct, there are currently no 35mm adapters available for 1/2 inch CCD's at the moment, i'm sure by the time i'm ready someone will have a solution worked out, even so i'm actually planning on getting the Sony 2/3 adapter and a set of decent HD Primes, oh and did i mention that i might be getting 2 cameras as this project may end up going 3D.
The other reason why the Sony is so important is the variable framerates, currently only the HVX and the Varicam offer this ability in camera. The HVX has fixed lenses and the Varicam is too expensive to buy 2 of them, so this leaves the Sony at a price point that is affordable.
Tony
Old January 24th, 2006, 10:50 AM   #27
There ya go!
Taylor,
........ i might be getting 2 cameras as this project may end up going 3D.
Tony
Well put Tony. Did not know about the variable frame rates on the XDCAM which is by all means an exciting offering. Good luck with the 3D thing, and keep us informed on how that goes. I also read something last night about the release sometime in the future of a XDCAM with 2/3inch sensors. Do not know how this will effect the price point when that rig arrives, etc etc. Best of luck.
Taylor Wigton
DP, Los Angeles
Old January 26th, 2006, 02:52 PM   #28
Just saw the article, but I have not read it yet (it's long, and I'm at work). So my request may very well be what you are intending to do, but just in case...
I would like to see you guys compare image quality in a couple of ways:
the standard HDV compressed quality, and the pre-compression HD output. I know that the Canon has HD-SDI out. I can't recall whether the HVX200 does or not off of the top of my head. The JVC has HD uncompressed out, and JVC has an HD to HD-SDI out box specifically for the camera. I have no idea what the Z1 has, if anything for uncompressed output.
I would also be interested in workflow. I know that you were planning, in the last part of the test, to test these cameras w/ various NLEs, but I don't know if your tests will start with the footage in the NLE, or start with getting the info to the NLE. It would be nice to see what any cameras shortcomings or exceptional features are as far as getting everything INTO the NLE (& whether you are going HD-SDI into the NLE or using the minDV tape/Rev-Pro/HDD/Sonys Blu-Ray Pro). It should be particularly interesting considering that you might be testing a GV Infinity, and possibly an HD-XDCAM, given that they use different media, and the GV in particular uses JPEG2000 compressed codec that the others don't use. I don't know what NLEs (other than GV's own NLE) can deal with JPEG2000 either natively or via a 3rd party plugin. Perhaps Final Cut Extreme or FCP 6 will be able to handle JPEG2000 (?) when they are announced (I'm guessing they will be announced at NAB, but that is pure speculation - I've heard nothing other than they will be announced soon, and FCX will run around $10k).
I, as well as many others will be watching the series closely, and can't wait for part 2 (and I haven't even really read beyond a quick skim part 1!).
Alex F
Alex Filacchione is offline   Reply With Quote
Old February 1st, 2006, 08:25 AM   #29
When is part 2?
Hi Taylor
This is fascinating stuff and a great way to test products. When will part 2 be completed?
DB
Dave B Mullen is offline   Reply With Quote
Old February 2nd, 2006, 11:34 AM   #30
Mini 35
I've shot with the Mini 35 a few years back and thought it was too soft thenm with and XL1 (before HDV). While the Mini35 fits the new cameras, I have never heard if the improved the innards for HD work? This could be why it looks even worse on HD footage than SD? I'm currently cutting a f900 show that used the Pro35 with Cooke primes - everyone who sees it assume sit's 35mm, but it was shot by a very experienced DP at a great location.
I'm hoping Cinemek makes a G35 that ataches directly to the JVC body and not to the end of the lens. Footage from the Cinemek appears far superioir to anything I've seen with the Mini35 and it's $1200 vs. $10,000!
I too am very interested in the new Sony HD XDCAM gear - though I was disappointed by the 1/2" chip decision. A friend at Sony says the footage so far looks as good or better than the f900.
Curious if someone like David Mullen would know how a 2/3" Digiprime or similar would work on 1/2" camera with adpater. I know the focal legth changes but would that prevent you from shooting with it? For instance if you wanted a 50mm look, just use a wider lens that equaled the 50mm on the 1/2" chips?
Lance
Lance Bachelder is offline   Reply
