What questions should be in an HD100 FAQ? at DVinfo.net
Old December 31st, 2005, 12:53 PM   #1
I'd like to develop a comprehensive FAQ this month and would like input from our members.
Here's a few questions I can think of right now. Please feel free to add to the list.
  • What is SSE?
  • What is the difference between the GY-HD100U, GY-HD100E, and GY-HD101E ?
  • What is an m2t and how do I watch it?
  • How do I digitize my footage with Windows XP?
  • How do I digitize my footage with Mac OS X?
  • How do I shoot "overcranked" slow motion?
  • What 3rd party battery solutions are available?
  • What lenses or adapters will fit on the Hd100?
  • How do I capture uncompressed HD?
  • What frame rates is the HD100 capable of?
  • Why can't I manually control the iris even thought the switch is on "M"?
  • What is the difference between 24 and 23.98? Which one should I edit with?
  • I see a bad pixel. What should I do?
  • How do I copy someone else's scene files onto my SD card?
  • What is the purple and green "fringing" I see when I focus? What is CA?
  • How should I configure my camera for a "film-look?"
Tim Dashwood
Old December 31st, 2005, 01:17 PM   #2
- What is "breathing" regarding the lens?
- How can I make a DVD from my footage?
- What are the advantages of the HD100 in contrast to the Z1/XL H1/HVX200? And the disadvantages?
- How does the "film-look" differ from that of the DVX100?
- What is the difference in the quality of the HD100's SD mode and an SD camcorder?
- How long do the different battery solutions last?
Robert Niemann is offline   Reply With Quote
Old December 31st, 2005, 06:19 PM   #3
- What tapeless harddisk recorder is compatible with the HD100?
- How should I shoot and edit if I want to transfer to 35mm film?
- What third party sound will capture the ultimate Hollywood Feature sound?
- How do I work around or get rid off the SSE?
- Should I use a filter or the in-camera ND when shooting in daylight?
- What editing program works with the 24p mode?
- How much light is needed for interior and exterior night?
- How do I get rid of the jidder?
- How do I get rid of the lagging and/or motion blur when I pan or tilt?
- What is the purpose of the shutter?
- How do I shoot a TV or computer monitor without having the bars running?
- What is the "Motion Smooth" and when do I need it?
- What is the "Motion Trans" and when do I need it?
- What are some tips for shooting in bright sunlight vs. cloudy day.
- How do you create a timelaspe effect?
Brian Duke is offline   Reply With Quote
Old December 31st, 2005, 06:41 PM   #4
Q: How can I output DV via 1394 from a HDV recording?
A: You can't, the GY-HD100 does not support real time down conversion to SD via 1394. Capture your footage in HDV and use your NLE to downconvert.
And replace all SSE references with SSF, it is a Fault, not an Effect.
Guy Barwood is offline   Reply With Quote
Old May 6th, 2006, 12:15 AM   #5
guys I have added these questions in the wiki page - if someone knows the answer please 'edit' the wiki page...
HD100 Wiki Page - http://snipurl.com/HD100Wiki
Ram Ganesh is offline   Reply With Quote
Old May 11th, 2006, 04:54 AM   #6
I'd like the FAQ to briefly breakdown the different intermediary codecs and their corresponding softwares.
A few words on JVC's version of hdv might be nice.
How to use the focus assist.
Software options.
Battery options.
Old May 11th, 2006, 08:43 AM   #7
Tim.
I get asked about White Balance a lot. Specifically if changing a configuration changes the WB. Maybe we can add something like:
Q: When I use one of the scene files that I download from the Net, do I need to change WB?
A: Yes, White Balance is independent from the color matrix configuration and should be reset for each scene you shoot. You can either use one of the presets in the camera (3200K for indoor or 5600K for outdoor) or reset the WB by placing a white card in from of the HD100 and pressing the WB button when the WB switch is either on the A or B position.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old May 12th, 2006, 12:44 AM   #8
Here's one I'd like to know - how the heck do you edit 24p with this camera (answers both both mac and pc users).
john
evilgeniusentertainment.com
John Vincent is offline   Reply With Quote
Old May 12th, 2006, 04:40 AM   #9
Hey John,
We should get together. I am using Lumiere HD and FCP 5.1 to cut my 24p stuff.
I picked up a MacBook Pro last weekend and it flies.
I'm hoping that it will get easier to do when Apple releases their "imminent" update.
However, I would like to suggest to Tim Dashwood that we have the "most recent" settings listed for Lumiere HD and FCP 5.1 for cutting our footage in 24p. It would also be nice to have a list that starts with capturing and ends with outputting.
Tom Chaney
Tom Chaney is offline   Reply With Quote
Old August 1st, 2006, 10:06 AM   #10
Capt. Quirk
I'd like to find a detailed Menu Settings for Dummies FAQ.
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old August 1st, 2006, 10:45 AM   #11
Thanks for bringing this thread back up Keith. It will get done... eventually.
Tim Dashwood
Old August 1st, 2006, 12:02 PM   #12
Capt. Quirk
Actually, I found it while searching for your post on the V/H settings, but I am equally unsure about many other settings too.
Old August 1st, 2006, 12:26 PM   #13
Here's the direct link to the rez tests you are looking for.
http://homepage.mac.com/timdashwood/..._rez_tests.zip
Tim Dashwood
Old August 1st, 2006, 12:26 PM   #14
Hi Tim,
the questions here asked are very good!
Where will the Faq be ready to seen?
I think it would be good as a sticky on these boards!
Mathieu Ghekiere is offline   Reply With Quote
Old August 1st, 2006, 12:35 PM   #15
Originally Posted by Mathieu Ghekiere
Hi Tim,
That is the plan. I have a great love for the board and I do the best I can with the time available, but unfortunately other things keep coming up.
In the meantime, it looks like information is being added to the HD100 Wiki FAQ and the JVC FAQ answers some basic questions.
Tim Dashwood
Tim Dashwood is offline   Reply
