chromatic aberation - Page 2 at DVinfo.net
Old December 20th, 2005, 05:50 AM   #16
Barry Wan Kenobi
That's really, really bad. One of the worst examples I've seen.
Was that shot at full telephoto?
Old December 20th, 2005, 06:12 AM   #17
Yes, open iris and full zoom.
I couldnt renew situation, JVC sent me another HDV100 to test.
Video is shot f4 and almost full zoom. (720P25)
Jari
Jari Pakkanen is offline   Reply With Quote
Old December 20th, 2005, 06:29 AM   #18
Did you test it already? Better or worse than the other one?
Diogo Athouguia is offline   Reply With Quote
Old January 16th, 2006, 10:15 AM   #19
Hi there! New here...
Just wondering what you are seeing in the file. I do not have a trained eye and cannot see what you all do.
Rich Everitt is offline   Reply With Quote
Old January 16th, 2006, 11:32 AM   #20
Look for the purple and green fringing, especially around high contrast areas. It's like riding a bike, once you know it, you will ALWAYS see it.
Those first grabs are particularly bad. The whole picture has a green/purple gradient over it and there is some serious ghosting too. The ghosting could be due to the CCDs though (or was "motion smoothing on?).
Mike Marriage is offline   Reply With Quote
Old January 16th, 2006, 04:11 PM   #21
Oh yes I saw that right away! I was wondering about JARI's. I was thinking that Barry Green was responding to his posted file... My bad!
Old January 16th, 2006, 04:57 PM   #22
On Jari's, look at the purple fringe around the white wood work of the hut.
Old January 17th, 2006, 05:36 AM   #23
mike motion smooth was on.
"eyes through a digital world"
Jemore Santos is offline   Reply With Quote
Old January 17th, 2006, 06:49 AM   #24
Ah, do you think that is what is causing the double image?
Old January 17th, 2006, 03:16 PM   #25
Jari's .wmv is a good example of "traditional" CA. The green fringing in one direction, magenta fringing in the other. Look at the bright highlights on the guitar frets, and the first wine glass shot, where the doily is out of focus.
As for Jemore's problem, I can't see this as being due to CA. I've never seen that type of color shift over an entire image. Could this be some sort of mis-alignment of the prism, causing some sort of internal reflections to one or more of the CCD's? Or, more likely some element of the lens out of whack causing this shift over the whole image? If it only becomes pronounced at telephoto, the lens is more likely the culprit.
If you bring Jemore's 1st and 3rd images into Photoshop, then look at the red, green and blue channels independently, it looks as if the problem is not isolated to a single CCD, as it might be if it were a prism problem. The CA in shot 3 (the out of focus element behind her shoulder) looks pretty standard, but the color shift on the wall in shot 1 is not typical at all.
Scott Anderson is offline   Reply With Quote
Old January 18th, 2006, 09:35 AM   #26
As already said, CA can be greatly avoided by not shooting wide open or full telephoto. Combining both of course is signing your death sentence.
But all lenses in this price range of under $10,000 will exhibit some form of CA, so that’s not the end of the world.
If you can’t afford the 13x, the only way is to learn how to work around it. But look at it from the bright side, at least you have a fully manual broadcast style lens with a full HD resolution camera and all that for under $6,000. If you look at it that way, it’s not a bad deal at all now, is it?
Michael Maier is offline   Reply
