Import Question - Page 2 at DVinfo.net
Old December 17th, 2005, 09:32 PM   #16
clip info
Tim does the below info seem correct or could my problem lie somewhere there?
Sitting my desktop, after having been captured through HDVxDV, the clip info is:
Dimensions: 640 x 540
Codecs: Integer (Big Indian --may be the watermark from HDVxDV), Timecode, Apple Intermediate Codec
Upon importing the files into FCP I get the message: "The following media files are not optimized are not optimized for FCP HD
It is highly recommended that you either recapture the media or use the Media Manager to create new copies of the files to improve their performance for multi-stream playback."
Once imported, Item properties for the clips are:
Vid rate: 23.98
Frame size: 1280 x 1080
Compressor: Apple Intermediate Codec
Data Rate 4.4 MB
Pixel Aspect DVCPRO HD (1080i60)
Anamorphic: Blank
Field Dom.: Not set
Dan Kutler is offline   Reply With Quote
Old December 17th, 2005, 09:48 PM   #17
You must not have set "720P" as the option when you used "expert settings" for batch exporting from HDVxDV. I think it defaults to 1080i.
So basically, HDVxDV is converting your footage into 1080i, and that isn't right. I saw your frame grab. That must be what happens when 720P is converted to 1080i.
Tim Dashwood
Old December 18th, 2005, 12:47 PM   #18
expert settings
I think I did actually click expert settings....are there any other loopholes?
Does all else seem correct in my clip info post above?
Should I be getting that error message in FCP?
Dan
