Settings in FCP5 for HD100U at DVinfo.net
Old December 15th, 2005, 01:36 AM   #1
Hi,
I am hoping that someone can help out here below and we can make these settings permanent in this forum so others can benefit.
Does anyone know what the audio/video settings under the "Final Ctut Pro" menu is to be set as:
1. Specifically the Sequence Preset Editor. Do you set the "Edtiing Timebase" to 24? or leave at 23.98? Makes sense to set it at 24? but I am not sure. And what about the other settings such as "QuickTime Video Settings" Compressor? what settings should that be for 24p editing? The default is DVCPRO HD 720p60. I don't see a DVCPRO HD 24p there.
2. Also what about the Capture Presets? Default is set at DV NTSC 48 kHz. Shouldn't it be DVCPRO HD 720p24 - 48 kHz?
3. The device Control Presets? Default is at Firewire NTSC. Shouldn't it be DVCPRO HD firewire?
4. What is the Digital Cinema Desktop Preview in "A/V Devices?
Thanks. Maybe we should all contribute to have HDV settings for mHD100U and FCP5.
Brian Duke is offline   Reply
