#16 | |
Contributor
So is that hardware support on the XenaHD or are you relying onthe processor converting the uncompressed AVI to ProspectHD "on the fly"? |
#17 |
CTO, CineForm Inc.
Prospect HD does all the compression in software, in real-time, no hardware acceleration is required on the Xena card.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
#18 | |
Contributor
Does ProspectHD take any advantage of your graphics card ie is the graphics card important? |
#19 |
CTO, CineForm Inc.
Graphics card is not very important, any recent card will work fine. The system specs for Prospect HD are listing here : http://www.cineform.com/products/ProspectHDConfig.htm , but generally a dual proc Opteron system with 2GB is fine. It all depends I what you want to do.
#20 |
What kind of spec's needed if you were to capture with AspectHD? Same?
Damnit Jim, I'm a film maker not a sysytems tech. |
#21 | ||
#22 | |
CTO, CineForm Inc.
#23 | |||
#24 | |
Contributor
#25 |
CTO, CineForm Inc.
John,
As the XenaHD card or Xena HS requires PCI-X you will not be able to build anything truely portable, as these cards require a work-station class motherboard. The soon to be available Xena LHe will work on PCI-e bus, so that will allow desktop class PCs to be used (and maybe shuttle class), when that card is out we may change our system requirements, although you will still need the fastest Dual Core CPU for real-time compression 10bit compression at 60p (note: if you only intend 10-bit at 720p24 then most P4 class CPU can do it.)
#26 | |
CTO, CineForm Inc.
Fortunately a component/HD-SDI input to a laptop doens't exist yet. When it does, CineForm is will be able to do some amazing RT captures. So please keep an eye out for the hardware that can do this.
#27 |
Hi David. Yes I was asking about using AspectHD in the same vein as ProspectHD was being discussed. Component/SDI capture. So what are the specs needed for say Xena LHe capture to AspectHD. I would be quite happy capturing 8bit 4:2:2 (AspectHD) vs. the 10bit 4:2:2 (ProspectHD) for the time being. Being I own ApectHD and don't plan on a dual Opteron anytime soon, what do I need?
What would it take 480p60 from my HD10 vs. 720p60 HD100 (future cam)?
#28 |
CTO, CineForm Inc.
Aspect HD doesn't currently support live capture from anything but FireWire. Capture from a Xena card is Prospect HD feature.
#29 |
Wanna fix it ? ;>)
#30 | |
Contributor
My point was that seeking hardware support from a card like the Xena would negate the need for a really fast dual proc machine. Technically or commercially that may not be possible (I'm guessing they may support DVCProHD as they do this already for their Mac based Kona cards) but I thought it was a reasonable idea. |
