#16 | |
Also, interlaced video is read out just as fast as progressive. You need to read out x number of lines in progressive in y time, but in interlaced you need to read out 1/2*x number of lines in 1/2*y time. Lines/time = some frequency. x/y = 1/2*x/1/2*y. So the ccd operating frequency for progressive and interlaced are the same thing. OR 720x240x60 fields = 720x480x30 frames. Sensor still operates at the exact same pixel clock.
www.engr.mun.ca/~wakeham/index.htm |
#17 |
But interlaced cameras only have to read out 1/2 the number of pixels every field (1/60sec for example), where as the HD100 samples the sensor in full progressive mode at 60fps (hence the 60fps capabilities of the analogue output).
The 60fps (48/50) is used by the camera for its frame blending. Perhaps a better choice would have been to use 30fps native only, therefore halve the data read out requirements and reduce the load on their processor to be able to use a single chip solution only and eliminate SSF altogether. Was there an absolute need for 60fps? Alternatively a slightly larger body with heat pipes could have been used to dissipate the heat of a single chip processing 60fps. What would you prefer: a slightly larger body with NO SSF altogether or the current body with the chance of SSF? Personally I'd prefer the former. While the small body is 'cute', more important is image quality in all conditions... |
#18 | |
www.ascentfilms.com |
