#91 | |
Contributor
nuff said |
#92 | |
My bad amigo and all the best of luck... |
#93 |
Stephen, no big deal, I just get into a circle at times telling folks what was already tried, etc. Most folks are just truely trying to be helpful. I appreciate all that.
We'll figure this bugger out yet. (Or buy Sony.) See ya'll around, Sean
‘I don’t know what I’m doing, and I’m shooting on D.V.’ - my hero - David Lynch http://www.DeepBlueEdit.com |
#94 |
Me Too
Today I hooked up the 50 Deck to my Avid Meridian system so I could use it as a DVCAM source machine going component out. After trying several configurations within the Avid and the deck, I was unable to prevent the unit from locking up.
This occured when a tape was inserted and during high speed shuttleing. The only way to get the deck back online was to disconnect the power cable for a brief moment. This is a bummer, since I was looking forward to downconverting the film-like hdv directly into the Avid for a look. Seems like the workaround is to downconvert to a Beta SP or Digi and capture. I've had no trouble controlling the deck on another system via firewire and FCP. I was however, hoping for an easy workflow when doing SD work on the Avid. -Dave Dessel |
#95 |
David, since you mentioned the "film like look" I wanted to make sure you are also aware that Avid still can't handle the 24p HDV format yet. At least not the MCAs or Xpress Pro HD. Kinda' sucks.
Sean
#96 |
I Know
Yes, I am aware of Avid's current HDV limitations. I'm using FCP for all of my HDV needs. FCP or AVID, it's all the same to me as my only concern is content and they are both fine tools.
However, one of the things I want to do is use the real-time down conversion in the deck to go in to my Avid Meridian System. As I stated earlier, batch digitizing does not work on this older system (4.5 years old) and the 50 deck. For SD projects, on this system, I'll dub to a Beta Format and then batch, until a solution can be found. Best, -Dave Dessel |
#97 |
David, were you trying to control the deck on the Avid via 1394 or RS422? I know you said 1394 for FCP but you din't say for the Avid.
Thanks, Sean
#98 |
Rs-422
Hey Sean,
On the Avid it's RS-422 that's causing the problem. I have no problems at all with Firewire. Happy Holidays, -Dave Dessel |
#99 |
That's what I thought. I am in talks now with our JVC Engineer for this region. I may mention you to him also as another person who can't get RS422 working. We have 2 of the BR50 decks now and I need to schedule room time in that suite to test 422 to the new deck. I'll be in touch.
Sean
#100 |
Sean,
I am happy to speak to the JVC folks. I E-Mailed you my contact information. Have an awesome holiday. -Dave Dessel |
#101 |
Thanks David. I found out who our JVC service rep is for the midwest (Ohio) and we have been speaking for a while now on several issues. He has our camera and is troubleshooting the latest mystery.
We had the camera stop recording TC and audio, even though the shooters were live monitoring it while recording. It just didn't record correctly anything but video. Strange thing is, that was in DV mode. Anyway, we are on track now. Thanks for the offer, Sean Mchenry
#102 |
Hi Barry,
This is disturbing news. Please let us know what you discover. -Dave Dessel |
#103 | |
HDV Cinema
Perhaps you meant 60:1 -- which still is only 270GB. That's about $250 for a 1394 disk. After a production, toss it on a shelf. A true removeable drive would be about $200. Later this year Maxtor will introduce Tapestry, a holographic DVD disc with a capacity of 300GB.
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c |
#104 |
Despite the math, he's still right. Who will want to browse hours of captured footage, bring it in raw and the sync the full rez version - by eye? For a full length feature or doc? How would you justify that time to a client who knows how a real shop should function?
That's a lot of extra work that would be avoided with proprer TC and the ability to batch capture. Sean McHenry
#105 | |
HDV Cinema
Let's look at the 30 min project which he posted about: 1) Someone is going to have to watch and log all the tapes to get a batch capture list into the NLE. Either you do that by shuttling tape and marking while risking tape damage OR you watch the tapes play from disk. The whole point of NLE is to eliminate tape and work from disk. 2) There is no need to sync anything because audio is already on the tape -- sorry -- on the disk. Already nicely divided by the computer into shots. 3) Simply delete the shots you don't want, or toss them into an UNUSED BIN, and toss the "good" shots into the 30 min. Timeline. 4) Put the Project file and an HDV copy on the disk too. Along with audio and graphics. Now put the disk on a shelf in case you need the source contents. Done!
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c Last edited by Steve Mullen; December 31st, 2005 at 10:14 AM. |
