HD 110 Lens Question at DVinfo.net
Old February 4th, 2017, 05:35 PM   #1
Hello -
I need to know if a FUJINON EAGLE TV-Z CAMERA LENS, S16 X 7 BRM-18B 1:14/7 - 112MM will work on my HD110 camcorder.
Thanks KF
Kurt Franz is offline   Reply With Quote
Old February 11th, 2017, 05:37 AM   #2
Re: HD 110 Lens Question
This must have been a really foolish question ;)........
Old February 11th, 2017, 10:36 AM   #3
In my opinion it wouldn't work.
It has 1/2" bayonet mount, incompatible with 1/3" JVC HD110 mount (you have to use special adapter to mount). Also it electrically connects with camera by pins on bayonet itself (as far as I remember), while HD110 uses cable connector for lens.
FUJINON EAGLE S16 X 7 BRM-18B is SD resolution lens for lower grade professional Sony DXC-325, DXC-327 cameras. I think, image quality will be low, even if you mount it on camera.
Anton Tokman is offline   Reply With Quote
Old February 14th, 2017, 09:06 PM   #4
Hello
Thanks for taking the time to reply. I picked up a good working body with a viewfinder and want to try it out. That lens was inexpensive and I was thinking go trying it if it was possible. Looks like I will need to try and find a cheap stock lens for the camera.
Best
KF
