HD100 supports PCM audio record/playback - Page 2 at DVinfo.net
Old October 21st, 2005, 12:51 AM   #16
Contributor
Originally Posted by Andrew Young
Could you please detail the steps you used to capture this audio? I have tried many combinations of settings and nothing has worked. I am using HDV30p material with the BR-HD50 deck and FCP5.0.2. When both sides are set to DV the clips capture but there is no audio. When the deck is set to output DV on both the switch and menu there is no audio, but when either the switch or the menu is set to DV, FCP (which is in DV mode) does not recognize the deck, or tells me it cannot capture because there is no video (in spite of the fact that it is set up as an audio only capture). I'd love to know how you made it work.
Andy
Reading Steve's original post he said he managed to do it WITHOUT deck control... manual record. Plus it sounds like he was doing it straight off the camera not through the deck:
Originally Posted by Steve Mullen
We know the HD100 does not downconvert HDV to DV. So when you switch the 1394 switch to DV and set the playback mode to DV -- nothing should come out of the 1394 port.
Yet there is a signal -- one that can be captured as "NTSC DV 48 kHz" WITHOUT video. (Also, with no real device control.)
John Mitchell is offline   Reply With Quote
Old October 21st, 2005, 01:43 AM   #17
HDV Cinema
[QUOTE=Andrew Young]
Andy
So would I as I can't get the PCM audio anymore. But when I told JVC I was having trouble, they said keep trying! They recommended playing on a normal DV camcorder. Which I will try.
They seem very sure PCM was implemented.
Old October 21st, 2005, 02:14 AM   #18
It's still weird. One would expect they (JVC) marketed that as a selling point - as it really is that...
Instead they seem very, very quiet about it...
Werner Wesp is offline   Reply With Quote
Old October 21st, 2005, 12:49 PM   #19
HDV Cinema
THey say they want NLE companies to support it before they go public.
David -- will CineForm support it?
Old May 30th, 2006, 11:33 PM   #20
Kino-Eye
Conclusion to this thread...
You'll find an important conclusion of this thread in Steve post in this thread at http://www.dvinfo.net/conf/showthread.php?t=68403 where Steve Mullen writes:
The thread pointed to does not have the complete story. Yes, one channel pf PCM audio is recorded. But, it is very distorted and so is unusable!!!
It must have been either an error in design or an experiment. For example, it being there does allow software to be developed to "get" it.
I wonder if the 200 and 250 will have PCM audio?
David Tames { blog: http://Kino-Eye.com twitter: @cinemakinoeye }
David Tamés is offline   Reply
