Low-light test shoot - Page 2 at DVinfo.net
Old September 29th, 2005, 08:40 PM   #16
Originally Posted by Sean Livingstone
Is that shoot with the stock lens?
Yes. The 13x3.5 isn't available here yet.
Old September 29th, 2005, 09:24 PM   #17
Originally Posted by Soroush Shahrokni
Michael check the footage again. I didnt notice it the first time I watched it either...but then I just jumped out of my chair when I watched it for the second time. Sad!
I'm sorry, but I watched both clips again, with my nose glued on the monitor, and couldn't see it. Where exactly are you seeing it?
Michael Maier is offline   Reply With Quote
Old September 29th, 2005, 09:51 PM   #18
Click for image
These are single frame's with split in the motion picture, not overall split in the motion picture. They are hard to pick up unless you're looking for them.
Stephen L. Noe is offline   Reply With Quote
Old September 29th, 2005, 10:53 PM   #19
Now that the split screen was pointed out I can see it in a handful of shots. You really have to look hard but I guess if the film was blown up to 35mm or even shown in HD on a big size TV, it may be more visible.
www.ascentfilms.com
Jiri Bakala is offline   Reply With Quote
Old September 29th, 2005, 11:13 PM   #20
Ok, I see it now. But even in the still frame you have to look for it. Did you bright the shots to make them more visable?
Old September 29th, 2005, 11:17 PM   #21
No, no enhancement. That was a screenshot from the QT player.
Tim D. What's the serial number on your unit?
Old September 30th, 2005, 10:15 AM   #22
Tim, is it possible for you to upload the first shot of your teaser or the close up of the girl in raw .m2t?
Soroush Shahrokni is offline   Reply With Quote
Old September 30th, 2005, 02:34 PM   #23
I've uploaded a few takes to my public folder. The original m2t files.
http://homepage.mac.com/timdashwood/...etup06-tk1.m2t
http://homepage.mac.com/timdashwood/.../setup16-2.m2t
http://homepage.mac.com/timdashwood/.../setup17-1.m2t
http://homepage.mac.com/timdashwood/.../setup18-1.m2t
Old September 30th, 2005, 03:14 PM   #24
I only saw it because someone pointed it out, it wasn't bad at all. If I already didn't know about the sse, I wouldn't have noticed at all. I thought it would be more pronounced. Easily taken care of in post IMHO. Still, it's a bummer to even have to deal with it at all. This cam is definitely not for newbies.
I'm scared to order one now. Sorry if that sounds wimpy, but I gave up being a guinea pig for new tech a long time ago. Let you young whipper snappers take the risks for now. hehehe
I think I'll just rent a DVX100a and shoot with that. Assuming the HD100 is still around, I can wait till the Canon and the Panasonic are released to make a final decision. Too much at stake to rush into things. And now, hearing about that new Sony cam coming out in spring , yet another thing to think about.
Joe Carney is offline   Reply With Quote
Old September 30th, 2005, 04:05 PM   #25
Finally, a true nugget of wisdom on this board!
Old September 30th, 2005, 09:22 PM   #26
Tim, bad news. I dropped the files on the timeline and sent them out to monitor. There is no mistaking the split when sent out to CRT monitor. It is not fleeting or flashing by. Take a look when the director says to the girl "fall down" on setup-06.m2t. Right when her face leaves the scene you absolutely can not miss the split for the rest of the duration of the shot. Damn it! This thing could kill one of the most phenomenal camera packages to come along in a long time.
It is what it is and there is no mistaking it. I posted an ISO on another thread for SD DVD. If you download it and burn it you'll see (if you haven't already). I asked you on another thead what the serial number of the camera in question was. Is it low??
Old September 30th, 2005, 11:17 PM   #27
The serial numbers are 8 digits, so it is hard to tell what they mean. There is probably some type of coding system that tells you when the unit was manufactured.
I'll email them to you so you can try to decipher them.
Old September 30th, 2005, 11:48 PM   #28
I saw it, but that wasn't why I posted the footage. The point of this test was very low ambient light, but I was fortunate enough to get a bit of split screen.
That's exactly why I'm doing so many tests. I wouldn't want to find this stuff out while in production.
What I find really interesting is how it "flickers" in and out. The intermittency is probably a pretty good clue as to what is actually happening and why. I need to test this in a controlled environment some more before I send this unit back to JVC.
Old October 1st, 2005, 12:06 AM   #29
It would be very difficult to try to identify an affected batch vs. an unaffected batch by analyzing serial numbers on any of today's camcorders. These numbers are not just a direct progressive sequence like they were just a few short years ago. Those numbers will tell you what the technician on that assembly line ate for breakfast the morning your camera was built, but without knowing how those serial numbers are coded they would be impossible to decipher properly.
Old October 1st, 2005, 06:34 AM   #30
Tim, thx alot for posting the clips!
