Upgrade Wishlist (updated with HD200/250 results)
When I exchanged my HD100s at JVC HQ in Toronto, I had a chat with the GM of Pro Sales for Canada. I told him some of my woes with the camera and wishes for a firmware update. He asked me to please write it all down and send him an email because he is in constant contact with the engineers in Japan.
They designed this camera based on suggestions from working cameramen, so it stands to reason that JVC wants as much input as possible from the end users. I just sent the email with my top-10 firmware wishlist, and then I thought that maybe I should post it and ask if anyone else could think of any other ideas (within reason for a firmware update.) I'll send the link for this thread to JVC if anyone comes up with anything else. Please don't bother posting frivilous posts about the split-screen problem. There are a multitude of those on other threads and JVC are well aware of that problem! Here's my top 10 most wanted firmware updates:
And now to my Mac software wishlist (for JVC and APPLE):
That's all I can think of for now. Tim EDIT: Please click here to see the new features implemented in the HD200 and HD250. Please add your requests in the same format so it will be easy to read if a JVC engineer happens to be browsing. Use the following format for lists (replace brackets with square brackets.) (list=1) (*) (b)Wishlist item 1 title(/b) Detailed description of how the function would work and why it would make the camera better. - (*) (b)Wishlist item 2 title(/b) Detailed description. - (*) (b)Wishlist item 3 title(/b) Detailed description. (/list) The list will look like this:
Tim,
Thanks for offering to help make this cam even better by providing JVC with user suggestions. The first things I noticed, could be implemented with the user buttons. 1. Add a quick link to the preset white balance. 3200 OR 5600. It's a pain to navigate to the menu and select the presets in fast moving shots. Sometimes you just know it's tungsten or daylight. Or at least close enough when you can't white balance. 2. Quick link to TC presets. Almost all professionals use timecode hours to set tape number and we start at 01:00:00:00. So even the reset to zero has to be modified in the menus. It would be nice to hit a button to get to the preset menu. While black stretch, black compress are nice quick links, these are even more important IMHO. I like the bars option BTW. Dave B |
#3 | |
That is already built in. Just set one of your USER buttons to "PRESET TEMP." and you have a 3200K/5600K toggle. Tim |
More suggestions for JVC and the HD-101 update
#5 |
Forwarded this Thread to Head of JVC China
The head of JVC China is on his way to Japan to consult with the head honchos about what to put into the new camera. I've forwarded this thread to him. Hopefully he'll take it to them and we'll see some of this great stuff in a new model down the road.
#6 | |
Also, I don't have a good resource at hand, but my quick calculation just now tells me that uncompressed 1280x720p60 at 8bit is 888mbit/sec...not suitable for firewire.
My Work: nateweaver.net |
#7 | |
That one is already built in (sort of.) However, it doesn't work like pro viewfinders on rods. Instead, just loosen the ring on the viewfinder and then pull the column out, retighten. You can adjust back almost 2 inches, but cannot go forward. |
#8 | |
The 24-bit idea is good, but I suspect the 16-bit 48Khz PCM stereo tracks are already recording. They just need to create a method to digitize them in sync. |
#9 |
Since I do both multicamera live-switch field productions as well as single camera work, I'd like the version that was shown at NAB where they removed the tape transport and replaced it with a 26 pin camera cable connector so you could control the camera from a CCU. I think a lot of studios now using the old GY550s would consider upgrading as well. The only problem is that the NAB prototype utilized the firewire output for the 26 pin which meant that you didn't have the option of using a HDD for single camera work. I could easily give up the VTR, but the loss of the HDD option would be a deal breaker and probably force me over to the XL-H1.
#10 | |
#11 | |
No one really knows yet, and there is no official word from JVC except the statement on page 4 of the ProHD brochure. Quote: "MPEG-1 Layer 3 audio tracks are encoded at 384 kbps, which is approximately CD audio quality, while PCM tracks are sampled at 16-bit 48kHz and recorded without compression in exclusive PCM audio sector on a separate part of the track." This statement is in reference to ProHD as a "concept" and not the actual functionality of the HD100. I think Steve Mullen is the only one who has actually tested for PCM audio, with mixed results. |
#12 | |
#13 | |
#14 | |
Barry Wan Kenobi
#15 |
"Quicker RESET of TC and an auto hour advance feature."
You can zero reset the time code data by simoultaneously holding down the USER2 button and the STOP button for about 1 second. Not very easy to do with one hand only, but better than using the menus. |
