#16 |
Barry Wan Kenobi
Pre-Nate, indeed -- Nate, those clips were extremely clean. Probably some of the best HDV footage I've seen. Very impressive, and really worked well with the stock lens too! If you remember -- were these mainly shot wide-angle?
#17 | |
#18 |
I just watched the clips again, and the more I see them, the more I like them. Great job Nate.
#19 |
As you say yourself Barry, and as already put by others, you don't know what tapes have been used in the camera before you shot. It doesn't matter you used a new tape. I'm 100% sure several different brands were used and the heads got guped up with different tapes lubricants. Do the same with a DVX100, XL2 or PD170 and tell me they won't behave the same way, maybe even worse. You just can't compare a trade show unit, which has been used and abused, to a normal running unit. I rather go by Nate's experience, who I know is using the camera the way it should be used in normal shooting conditions, than go by some bad moments had in a trade show with a public unit. But that's just me.
I say myth, because I remember in the early days of DV, all the pros, and also sony, in a desperate effort to protect their higher end line, were saying DV wasn't good enough because it had lots of dropouts and etc. Even Panasonic was preaching how plain DV wasn’t good enough, because it wasn’t as robust as DVCPRO etc. Today, DV is used for professional work in large scale. Where did the DV dropout myth go? I hear the HDV codec is less prone to dropouts than DV. The thing is when it happens, it's uglier, because of GOP. But it hasn't stopped DV and it will sure not stop HDV, specially ProHD, which has been proving to be a better solution. How many professionals out there shoot DV with a direct to disk solution? I would say nowhere close to 30%. If HDV is safer, I'm sure even more people will take the "risk". As many put it, just use high grade tape rather than the 5 tapes for a dollar deals one finds around. Bottom line is, the HD100 is a winner IMO and as already pointed out, the HVX200 will sure have a run for it's money. Specially that it can't shoot HD for under 6k. I think they both have desirable features need in the field. One will just have to pick the ones he needs most. I'm actually really surprised with the HD100. I didn't expect it would be that good, based of the JVC HD1. But what I have seen from it, proves me so wrong. The mini35 test, had the excuse of had used a $60,000 lens, which is beyond reach of the large majority of users for this camera. But Nate’s test is just straight out the box with the stock lens. It looks great! I know Nate knows what he’s doing, but it just proves the camera is a winner |
#20 |
Nate, was the white clip on 100 or 108?
#21 | |
#22 |
Aha, no trust in the auto-knee? or just because of the danger with the reflecting surfaces?
Gain on 0 dB? |
#23 | |
Yes, 0db gain. |
#24 |
I think that it is the best choice for the shot with the bus. I might have used the auto-knee with the big tilt-shot, but it looks great like this also...
Too bad you can't choose auto-knee with a button, instead of with a manu-setting... |
#25 | ||||||
Barry Wan Kenobi
And as the tape I showed demonstrated, ProHD does indeed appear to handle dropouts differently. On the Sony, each of those dropouts would have resulted in a half-second freeze-up. On the JVC, it just scragged portions of the picture. Quote:
Dropouts are a reality. Their frequency can be mitigated somewhat by using the same brand of tape, high-quality tape, cleaning the heads, etc. But they do happen. It's the nature of the format (and it's a primary reason DVCAM and DVCPRO were developed). And dropouts affect HDV a lot more significantly than they do DV. Quote:
What JVC has done is scramble the data around on the tape, so they can minimize the impact of a dropout AS COMPARED TO SONY's FORMAT. A Sony dropout seizes the entire GOP. A JVC dropout scrags a portion of the picture (and occasionally seizes a whole GOP, I've seen that too). But in both cases the dropouts are far more destructive to the picture than they are in DV. Look at the clips I posted again -- every dropout is a significant scrag that lasts for multiple frames. That's the nature of having a GOP-based codec -- if something gets scragged, it's scragged for the duration of the GOP and there's *no way* around that. Sony drops the whole GOP, JVC just lets the scrag play through, but it happens. With DV, that dropout may have glitched a little bit of one frame. With HDV, it's going to affect an entire GOP, each and every time. Dropouts are always uglier on HDV than they would have been on DV. Quote:
Look, all I'm saying is that dropouts do happen. Pretending they don't serves no valid purpose. They do happen, if you're recording to tape they will happen, and that doesn't mean the camera won't succeed, it just means that it's a risk-management game you have to play. I would think that anyone who values their footage (and, frankly, if you don't value your footage, what are you doing shooting on high-def?) would want to be aware of what the risks are, and what the options are for minimizing that risk. For some people, the cost savings of using a $3 tape will be worth whatever dropouts they get (that ain't me, but I know that a lot of people will choose that option). For some, using a $5 tape will provide all the margin of safety they think they'll need (and I wish them well). For others, using the $18-$25 HDV tape will be what they think they need to do. For guys like me, with zero tolerance for scragged footage, that means a backup recording mechanism (HDV Rack or DR-HD100). Pick your level of risk and your strategy of management and go forward. But do so with your eyes open, recognizing the very real issue of dropouts and their more-serious impact on HDV footage. Don't cling to the false notion that dropouts are a "myth", or you'll be hating life when you get hit with 'em. |
#26 |
Dropouts can happen and it is in no way related to the format, but the tape (basicly). Very true.
Some things need to be said. 1) from personal experience: experiencing 3 dropouts per tape is an awful lot. Since the days I use an XL1 I never had more than 1 dropout per 3 or (perhaps) 2 tapes... (that's a factor 6 to 9 less!) 2) It is no myth that HDV is more resistant to dropouts than DV. Dropouts are caused by bad patches of tape, or dust or worn heads - not related to the format. BUT, HDV writes the image data in different places on the tape, making a difference whether or not the dropout will affect the image or can still be corrected by the error-correction. The dropouts might be there, but not visible to the way it is written to tape and then corrected if needed. It is a reality that HDV is somewhat robust against *small* dropouts. Mind you, a big dropout will eat a big enough patch on the tape to make it impossible to compensate, so HDV isn't any more robust angainst serious dropouts then DV - just the very small ones. 3) I can't back Barry more on this: The ProHD format can't avoid any more dropouts than sony's standard HDV, but it handles them better apparently - and that is what it is all about, sometimes... |
#27 | |
#28 | ||
#29 | ||
Barry Wan Kenobi
#30 |
Barry Wan Kenobi
Hey Chris, this thread should probably be split out -- it's taken a significant turn away from Nate's excellent clips and we've drifted off onto a dropout tangent... probably should be reorganized to keep Nate's original thread on-topic.
