Arriflex mounted lenses for HZ-CA13U - Page 2 at DVinfo.net
Old September 30th, 2011, 07:06 PM   #16
Re: Arriflex mounted lenses for HZ-CA13U
Shaun, I hope you are wrong about this lens fitting on the COPLA. I did do some research before buying it and the thing that made me go for it was this video which definitely references both the HZ-CA13U PL mount AND the Lomo Lens Zoom 16OPF12-1 10x10/2,5.
Note the sharpness shown on the video. Also, unless I'm totally off wack, Tim Dashwood bought one of these and had it converted to PL mount.
Thanks for commenting and sharing your views!
Enrique Vega
http://enriquevega.com
Enrique Vega is offline   Reply With Quote
Old October 1st, 2011, 02:22 AM   #17
The pictures look fine there, although I'd be cautious about making judgements using a highly compressed on line video. I recall seeing a demo on how good compression was and they showed two samples, one was softer than the other. It turned out that the sharper looking one was the compressed version and the compression had removed the DPs diffusion.
Brian Drysdale is offline   Reply
