View Finder trouble at DVinfo.net
Old May 20th, 2011, 09:05 PM   #1
View Finder trouble
I have a 110 and am having trouble with the view finder. It works at times but at others it is funky with a purple haze and other color trouble. Sometimes I can't see anything. I plug it in and out and sometimes it helps. Any suggestions? Thanks.
Mark McNamara is offline   Reply With Quote
Old May 20th, 2011, 10:44 PM   #2
Re: View Finder trouble
Have you tried cleaning the contacts? If yes, then you might have to get it serviced or buy a 'new' one.
Old May 21st, 2011, 12:20 AM   #3
" New One" refers to the view finder?
Thanks.
Old May 21st, 2011, 01:30 AM   #4
Yes of course...but I suggest you try to get it serviced first. It might be possible to fix it.
Old May 21st, 2011, 10:04 AM   #5
I had trouble with my HD100's viewfinder. It showed only every second line. It was replaced by JVC on warranty.
Joachim
Joachim Claus is offline   Reply With Quote
Old May 21st, 2011, 05:10 PM   #6
Thanks for the help!
Old May 21st, 2011, 08:22 PM   #7
Hi Mark,
I have a110 also.
Had a slight problem with the viewfinder a few months ago.
I agree with Sareesh, try cleaning the contacts. I used a marine grade electronic cleaner I think it's made by a company named CRC.
Anyway, sprayed it on the contacts waited a few seconds and wiped off residue with a Q tip.
Presto, no problems for four or so months now.
Give it a try before spending on service.
Can't hurt..
Jay Webster
WPI/NY
Jay Webster is offline   Reply With Quote
Old May 22nd, 2011, 03:54 PM   #8
Thanks Jay. I will definitely try that. Here in Haines Ak I should have no trouble finding a marine grade cleaner.
