#106 |
When Panavision (who were first and foremost a lens manufacturer before they got into the camera building business) tackled the F900 conversion a few years back, the challenge they set themselves was to build lenses that could resolve as well as their 35mm lenses within an image area 1/4" the area of 35mm. That took a LOT of engineering--they were essentially doubling the resolution of their previous designs. SD optics have always resolved more than the format; now HD optics have to do the same, which means several times better resolution than the SD versions. It's an interesting challenge.
Charles Papert www.charlespapert.com |
#107 | |
#108 | |
Anything less than a HD (true spec as Barry puts it) will be basically what the stock lens is. The Aberrations will be corrected most likely. Your analogy with still cameras doesn't really hold. Moving images is a whole different thing. You say 1/3" lenses are not in the same category as 2/3". You mean price? The smaller the CCD the lens is for, the more complex and expensive it's to make. So a 1/3" HD lens is harder to engineer. You can't just count the size of the glass, which is not really smaller anyways. I wouldn't be sure your Fuji S20x6.4 (is that what you have? I'm just guessing by the 20x factor) which is actually an industrial/professional lens, will out perform the stock lens. Maybe it won't have the chromatic aberrations, but that's a defect. It will most likely be corrected. But I think your lens would look softer. I have used this lens with a DSR500 and it looked softer than when I used one of the Fuji true Broadcast lenses with the same camera. I remember it, because we were trying to find out if there was really a difference between the professional/industrial series and the Broadcast series. There was. So if it didn't match a higher SD lens, I think it wouldn't match a lower HD lens either. As Charles points out, a lens needs to resolve more than the format. Of course, it's impossible to tell for sure without testing. But the curious thing is that the stock lens for the HD100 cost about $800 while your 1/2" SD lens cost alomost $3,000. http://www.bhphotovideo.com/bnh/cont...goryNavigation |
#109 | |
When you say it does a fine job, I'm thinking you mean with no chromatic aberrations? As I said, fuji will most likely correct that. Otherwise, I can't see how the Z1 lens would out perform the HD100. |
#110 |
Find an NAB Handbook and Peter Gloeggler's contributions on lens and CCD relationship. It's brilliantly written, and whether you're an engineer or layperson, (or in between), it makes a lot of sense and is very informative. I'll see if he'll allow it to be posted, but it deals with why and how lenses resolve the way they do with various CCD sizes and types. You might be able to Google it, as it might be online already. I'm on a slow connection overseas, or I'd have a go at it.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#111 | |
Barry Wan Kenobi
Sample pics of Z1 (well, actually FX1) aberrations are available on the eidomedia site, at http://eidomedia.com/hdve/ziess_fuji.htm When you say that Fuji will correct it -- do you have basis for that? Do you know of examples where such a thing was corrected in a past product? I'm thinking that at the price point they engineered to, there's not likely going to be any correction for it. But I'd love to be wrong about that. |
#112 |
lots o f questions
hi all
got a few questions if anyone can help What would happen if you used the standard hd 100 lens with the mini 35? Would it be possible to use the mini 35 on a magiqcam steadycam rig or would the fact that you would have to use a fairly wide lense to keep focus without need of a focus puller make the employment of the mini 35 redundant Also would the mini 35 be too heavy? If you shot footage on the longer end of a long lens would this narrow your DOF even though the angle of view would not be the same. Sorry if these questions sound dumb I'm just dunmb and curious I guess Basically is there any way of acheiving filmic Dof without using mini 35 Thanks Guys |
#113 |
me again
Anyone know the best way to focus on a steady cam rig if you are using hd would you have to have an hd monitor I heard an sd would not be sifficient
Thanks |
#114 | |||||
This link could help you to understand how the mini35 works and what it does for you: http://www.pstechnik.de/en/digitalfilm-mini35.php Quote:
I'm sure somebody with more experience will chime in to add some more details. If you want information about video production cameras and etc, you couldn't have come to a better place. Don't hesitate to ask the questions you have. You will sure get your answers. Nobody here will think you dumb or anything. We are all in the same boat here. We're all learning new things everyday. Besides, people are nice and polite around here. Another tip is to use the search function. Maybe your questions have already been asked by somebody else, and you can get your answers straight away. Welcome on board. |
#115 | |
#116 |
Greg:
The Mini35 hovers around 15 lbs fully loaded (depends on camera, lens, accessories etc). I think the current top end Magiqcam can accomodate this, but not all models. As you guessed, pulling focus with a Mini35 for Steadicam is a can of worms. When you are working with a front end that is essentially a 35mm setup, you associate the challenges of the format, and for Steadicam that requires a wireless focus system. Any Steadicam operator who works in 35mm (and most who work in 16mm or 2/3" formats) will have the gear that is needed to fly and pull focus with this system; those who have rigs that oriented towards DV (such as the Magiqcam) will be in a bit of a pickle. Probably the easiest solution is to simply use the standard configuration of the camera on the stabilizer, then use the Mini35 for non-moving shots. I did this once while helping out on a shoot, and the footage cut in well.
#117 | |
Space Hipster
#118 | |
#119 |
Many Thanks
Michael, Chris and Charles,
Many thanks for the reply. my questions were a bit garbbled but I think you guys got nuts and bolts of it. You've helped a great deal. I was particularly interested about shortening the dof on the standard hd 100 fujinon lense by shooting at the longest setting did I get that right? Anyway many thanks again. I'm paying close attention to these pages as I hope to be getting an hd 100 (when in finally turns up in Uk that is) I'm also thinking of getting the new animagiq steadycam would this be a good combo with the jvc? Thanks for making me feel like not too much of a fool. Greg |
#120 |
also
Sorry guys I meant to ask this yesterday.
If I had the hd 100 on a steadycam rig and I wanted to make sure I was always in focus would the monitor I use have to be hi def or would a normal lcd be sifficient or would the fact that I would be on a fairly wide setting anyway make it a thing not worth worrying about too much? or I guess what i'm trying to ask is - How important is focus when shooting dv given the fact that dv is always trying to flatten the dof? Hope this makes sense love to hear your views Greg |
