HD101 clips now available from (H)DV Info Net - Page 2 at DVinfo.net
Old August 5th, 2005, 05:19 PM   #16
Big dissapointment. Im waiting for mine to be shipped, but those footage looks like blown up SD of some kind...even worse!
Soroush Shahrokni is offline   Reply With Quote
Old August 5th, 2005, 06:34 PM   #17
I really hope the disappointment is due to the recompression in Apples H.264 codec. I am also waiting for mine to arrive soon! If this is its best "behavior", I'd better stick to my HD10. I have way better things comming out of the HD10 than from this samples! Again, I REALLY hope is the H.264 thing. And even with blamming on it, what is the Blue-Ray future? Is this it?
Luis Otero is offline   Reply With Quote
Old August 5th, 2005, 07:00 PM   #18
Originally Posted by John M Burkhart
Since you've actually used it, what's your gut reaction? How did it feel, was battery life an issue (I believe you alluded to that). What was annoying with it? Inquiring minds want to know!
The camera is battery hungry. We bought 3 of the larger JVC batteries to go with the camera and I'm pretty sure 40 minutes is about the most you'll get out of one.
An Anton Bauer or V-lock adapter is going to be essential with the camera.
The camera is extremely well built with only the VF, battery surround, and lens bayonet mount being pastic.
The menu control is the best I've used for access and display in this type of camera.
I think both the VF and LCD on the JVC to be poor. I asked one of our cameramen for his opinion and his answer was it what he would expect from a camera at this price point. I think that was his diplomatic way of saying you get what you pay for.
I would say the LCD is below that of a PD170 and DVX100.
Personally I struggle with the VF, but then I don't spend 10hr days looking down the spout as a job.
Our Z1 came through between shoots and I checked the VF and LCD for a comparison and find it a large improvement on the JVC. I'll be interested in others opinion on this. There is also mirrored ghosting in the VF of some of the VF displays.
Maybe someone will introduce an aftermarket VF like what was available for the Canon XL's.
Focus assist works well. All controls are easily accessable, although the VF peaking and brightness dials would of been better on the front of the VF.
A zoom rocker incorporated into the handle would of been a nice touch too.
On other still shots we have grabbed there is chromatic aberration happening with the lens.
The 16x on it also has 85mm diameter which means a Chroszial Sunshade goes on the front no problem. Annoyingly the Fujinon Wide Angle Lens Adapter is slightly less in diameter so you will need a separate adapter ring for that.
Haven't done much testing with the Fujinon W.A Adapter, but we have dubbed it the 'Slightly Wider Angle Adapter'
I can't touch the Century Optics HD Adapter for the Z1 which is a stunning bit of glass. I would imagine Century will have something out for the JVC.
There is noise in the picture, its not ditracting from it but it is there. one of our cameraman joked it was nice of them to include 500ASA grain to the picture.Oh how we laughed.
The camera RRP NZ$9995 with the W.A adapter included. I believe if the camera only did 16:9/4:3 SD dv/dv 25p it is still a great camera at a great price. And at this point it's pretty much all we can market it as, as there is no edit support for Prohd 24/25p
The cameras form factor is excellent and even balances well on the shoulder with the standard JVC batteries.
Now the very bad news. Our camera is going back to JVC. Through our extensive testing we have discovered two pixels gone on the CCD.
One black and one white. If you cap the lens and introduce gain the CCD looks like the milky way. We even nick named one group of pixels 'Orions Belt'
Also through hooking the camera up component out into a HP L2335 LCD display there is some sort of red noise evident on the CCD. Even stranger is this effect is more pronounced on one side of the CCD than the other, almost split screen.
We are of course hoping we just got a bad camera but when I saw the post below I was a little more concerned:
http://www.dvinfo.net/conf/showthread.php?t=48808
Our supplier is getting another shipment on Monday so they can compare our camera with those to see what the deal is.
Anyone wanting to test there camera, you need to run it off the AC supply for at least 3hrs, cap the lens, close the iris and introduce gain.
We are a rental house in New Zealand and do not sell cameras so I have no prejudice against JVC, Panasonic or Sony, we buy what people want to rent.
I put the clips and tif's up as we were in the unique postion of actually having a camera before the USA or UK! We rely on the net for feedback on gear from markets that have access before us. I saw it as a way of repaying those that have done it in the past.
It also has been an excellent learning exercise on getting to know the gear we rent.
I look forward to other opinions and thoughts on the camera, I hope you gain something from our experience so far.
Edit:Originally Posted by Tim R Young http://www.dvinfo.net/conf/showthrea...495#post342495
The only problem we could find was when we put the camera up to 18db of gain one side of the screen was darker than the other and slightly discoloured ... maybe just a problem with this particular camera but might be worth watching out for??
Scott Webster is offline   Reply With Quote
Old August 6th, 2005, 12:19 AM   #19
Captured some bmx riders pulling tricks in a skate park. Also got some rugby league footage.
Did these 720/30p with 'motion smooth' on. If Chris is interested and if I managed to catch something worth editing together, we'll offer it up for posting.
Should be good to go by Wednesday.
The week of the 15th our Z1 should be back in and we'll line up both cameras on a dsc chart, pull tif's and post them.
If the opportunity arises I'll try and get one of our crew to take the camera and see what he can do with it.
I hope we see more feedback from Europe and Australia.
Old August 6th, 2005, 12:40 AM   #20
It interesting that these problems exist considering they are shooting a motion picture which 2 of them at the moment.
http://www.jvcpro-australia.com/JVCP...t&elementID=90
I guess they must have something going for them.
Sean Livingstone is offline   Reply With Quote
Old August 6th, 2005, 10:15 AM   #21
Thanks for posting notice of this press release, Sean -- I wasn't aware of that before.
Old August 6th, 2005, 10:55 AM   #22
suspended -- contact admin
First of all it is generally recognized that in order to rival 1080i you need 720p shot at 60 frames per secound. 720p60 is the highest of the HDV formats and it gives you the greatest pixel count. 1080i comes in secound place and 720p30 comes in last. However the higher pixel count of 1080i does you no good if the compression engine cannot handle it. Sony HDV users may be satisfied with the 26 megabit per secound bandwidth for handling fast motion but broadcasters do not have this bandwidth available. Broadcasters are limited to 19.7 megabits per secound and if there is a subchannel in the background they may have only 15 megabits of bandwidth available. This limited bandwidth was not satisfactory for the diving shots at last years Olympics and caused horrible artifacting. Had the JVC HD100 been available it would have blown any 100,000 dollar 1080i camera out of the water and would have provided good artifact free high definition footage for the diving shots at last years Olympics but of course the footage would have been softer. I much rather prefer a softer high definition than a high definition full of artifacts.
Tommy James is offline   Reply With Quote
Old August 6th, 2005, 03:26 PM   #23
Rocket Rentals
I'm from the same company as Scott Webster - There is quite a bit of a difference between these "small" video clips and the native HDV files. I'll see what I can do about posting something in HDV 720p30.
The general idea was to use the stills to give a rough idea as to what the picture quality was like, and the mov's to give you an idea as to what the movement was like. The movie clip was never intended to be viewed as "this is what you get exactly."
You have to remember that not everyone on the net has super fast internet connections, so a format and size was chosen which was easy to gain access to (and add to that, our connection to the net isn't super fast either).
Matthew Redmond is offline   Reply With Quote
Old August 6th, 2005, 03:45 PM   #24
Originally Posted by Scott Webster
The problem we had (and I'll confirm with the editor) is we chose the FCP codec '720 p30' (or it could have been a blackmagic choice)
We don't know what it was doing to the footage off the HD101 but we didn't have any problem bringing it in by firewire. Chose the H.264 as we were editing in FCP and it seemed a good choice to allow the most universal ability to playback the files.
If anyone has any other suggestions as what the FCP5 setting should be to bring in the footage, we would love to have them. We had no joy with prohd 720/25p material.
Scott,
Thanks for the footage. since it was shot in 720p30, the proper setup for FCP 5 would the same. There is an Easy Setup selection for that format. I would like to see some clips in the native format as others have mentioned. In FCP if you export using "QuickTime Movie" as opposed to "Using QuickTime Conversion", choose "Make Movie Self Contained" and your file will be the same format as the timeline in which you edited, in this case 720P30. You may have already know that but I just wanted to mention it.
We are considering this camera as our entry into the HD world and my boss has shot Beta SP all his life si he is quite picky about the quality and artifacts.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old August 14th, 2005, 04:46 PM   #25
These particular clips have now been withdrawn, but we'll have others available soon. Many thanks to Scott Webster and Matthew Redmond for sharing this video.
Old November 22nd, 2005, 05:55 AM   #26
That bad?
To make things hard for myself I used a Manfrotto 501 tripod. Never again.
Are 501's really that bad, In every shop I ask which tripod is best for a JVC HD100 and they suggest the 501?
Which Tripod would you suggest?
Cheers!
Steve Brunton is offline   Reply With Quote
Old November 24th, 2005, 11:13 AM   #27
501 has been great for all my projects with the HD100 and other cameras. Maybe that is a defective one... If you ask me for a recommendation, that would be mine: Manfrotto 501 with a good Manfrotto tripod.
Luis
Old November 24th, 2005, 11:24 AM   #28
Luis
It depends where you're coming from in the business, Luis. If you're a video hobbyist and the only tripod heads you've used are the ones you've bought for yourself, then a 501 is probably going to be one of the nicer ones you've seen in a store and had the opportunity to check out or purchase.
If you're coming from a professional background and ever used something like a Sachtler 7+7, or O'Connor Ultimate (heads that cost $3-7K), then a 501 is going to leave a lot to be desired.
If it works for you, that's all the matters.
My Work: nateweaver.net
Old November 24th, 2005, 01:35 PM   #29
To add to what Nate Weaver said (in a parallel). If you can master a cheaper head that 'sticks' occasionally and get great results then you've mastered your tool. 501 and 503 are decent heads, but just like anything else, they are tools that you have to master. If later on down the road you get a Sachtler, the skill you learned on a 501 will make your skill with a Sachtler even better.
If you can work it and get satisfactory results then NOBODY knows or cares what tripod your camera is sitting on.
best,
Stephen L. Noe is offline   Reply With Quote
Old November 24th, 2005, 10:12 PM   #30
Nate,
I underderstand your point, but the 501 is widey use not just for hobbyists (by the way, I am not one and have successfully used it in short, feature, spots and documentaries). If someone is not willing or just cannot afford to pay $3-7K for a head, the 501 is more than enought for basically any type of filming application.
Just because in the "professional" world (meaning the big companies) are in the position of spending that type of money, it doen not preculde for a more conciencious cinematographer to use the 501 with excellent results. Is just a matter of skills and the ability of the opertor to utilize them with the resources at hand.
Just my 2 cents.
Respectfully,
Luis
