Redrock M2 Encore & JVC Hd 201 (or 200) at DVinfo.net
Old May 5th, 2010, 12:04 PM   #1
Hello,
anyone using Redrock M2 Encore & JVC Hd 201 (or 200) ?
Just to know how to activate the "built in automatic flip image" on the camera when using a 35mm adapter, and, so, get rid of the microX encore flip device, just to have a less cumbersome rig
And, of course, tips & tricks are welcome...
Thanks in advance,
Giovanni
Giovanni Chironi is offline   Reply With Quote
Old May 6th, 2010, 02:15 AM   #2
Going completely from memory here, as I do not have the camera in front of me, I think you go to CAMERA PROCESS on the menu, go to the NEXT page and there should be a ROTATE option which will flip the image 180 degrees. Anyone please correct me if I am wrong. This option is a brilliant addition to the 200 series.
As for tips and tricks, three keys things:
1. Have a good HD monitor at all times
2. Have an experienced focus puller
3. Have lots of light, as you are losing at least a stop, of course depending on the lenses you are using. We had a arris -2K, 800w and 650W with dimmer.
I recently posted a thread here with a link to a behind-the-scenes on our feature film where you see our 201 on action with a 35mm adapter and Minolta lenses, with interviews with the camera operator and DP. Take a look if you get a chance, as it might be helpful.
All the best
Dan
Canon C300 Mk2 x 2, Rotolight Anova Pro and Neos, Ronin Gimbal, Phantom 4 Pro UAV www.danthecameraman.co.uk
Dan Parkes is offline   Reply With Quote
Old May 8th, 2010, 12:58 PM   #3
Thanks, Dan, for your advices
I spotted from time to time at your "Ambleton Delight": my compliments to you.
...and, yes, I definitely saw your "behind-the-scenes" !
Ciao,
Giovanni
