Thread Tools
Search this Thread
Hollywood Studio Rentals
New Article From Broadcast and Cable
So does this thing have the 6 frame dropouts, like the Sony has the 15 frame dropouts? Is it supported by FCP?
<<<-- Originally posted by Michael Struthers : So does this thing have the 6 frame dropouts, like the Sony has the 15 frame dropouts? Is it supported by FCP? -->>>
1. No, its 24p mode is actual 24p, with no redundant frames recorded (like the DVX100 and Varicam) and no frame dropouts. 2. Not yet, unless you count transcoding to a currently supported FCP timeline codec (such as 8 or 10 bit uncompressed HD, or DVCProHD 720p24) first. |
It won't have *any* dropouts if you're recording directly to the optional onboard hard disk recorder.
#5 |
"It won't have *any* dropouts if you're recording directly to the optional onboard hard disk recorder."
Chris beat me to it, that's exactly what I was thinking. This thing is sounding better everyday.
Luis Caffesse Pitch Productions Austin, Texas |
#6 |
HDV Cinema
There are NO 6 frame DOs. Ugly rumor I may have started. :) The 6 GOP frames are stored on 60 tracks. All the GOPS are in tiny blocks scatter through the 60 tracks. A DO takes out a few blocks which error correction should fix. A really big DO takes out some macroblocks, but can never take out a whole FRAME. DV stores 6 frames over 60 tracks too.
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c |
#7 |
The folks over at cineform stated they anticipate no problems supporting it when it comes out. It's HDV, but at 24p. Good news for Vegas folks.
#8 |
Schweet. Was there an indication how much the optional hard disk recorder was going to cost, and the storage size?
#9 |
What? On-board hard drive? Do you mean on-board the cam itself, or as a Firestore type device?
#10 |
Frederic, it's going to be an external add-on recorder, most likely based on the FireStore FS-3.
