1.1 Mpixel ??? at DVinfo.net
Old March 12th, 2005, 04:22 AM   #1
Contributor
1.1 Mpixel ???
Hello,
If the CCD is
1280 x 720 = 921600
1440 x 1080 = 1555200
1280 x 1080 = 1382400
is not near 1.1 Mp, but if is
960 X 1080 = 1036800 or
1440 X 720 = 1036800
may be near 1.1 Mp
in 1440 x 720 you can have more of 720P
and more of a field of 1080i hdv (1440 X 540)
I'm wrong ???
Bye
Francesco
Francesco Marano is offline   Reply With Quote
Old March 12th, 2005, 10:39 AM   #2
What confuses the issue is whether the 1.1 megapixel spec is for total pixels or only effective pixels... also we don't know if these CCDs use Pixel Shift.
Old March 17th, 2005, 06:54 PM   #3
Hi,
maybe its just somewhat larger than 1280x720y like the old HD10 had 1280x960y chips too.
On some cameras this extra pixels can be used for software based camera stabilize function, due to moving the actual image area on the chip as required for compensating shaking.
However, most important is that it has TRUE 1280x720y resolution per each chip on the 3-Chip (CCD) solution.
Axel Mertes is offline   Reply
