ProHD for Blu-Ray Release? at DVinfo.net
Old July 25th, 2009, 09:21 AM   #1
Hi there --
Is ProHD footage shot in 720p of sufficient quality for BlueRay DVD? What's a good way to upscale the footage to 1080p? Can this be done with FCP or is specialized equipment needed?
Cheers!
Stefan Immler is offline   Reply With Quote
Old July 25th, 2009, 11:37 AM   #2
Originally Posted by Stefan Immler View Post
Hi there --
Cheers!
720p24 (and 23.976) is part of the Blu-Ray standard.
There is a chart on Wikipedia:
Blu-ray Disc - Wikipedia, the free encyclopedia
Old July 25th, 2009, 10:51 PM   #3
Yes, it is good enough.
Yes, Pro-HD footage is plenty good enough for BluRay IMHO. As has been said many times before, resolution is only a small part of image quality- there is lighting, technique, editing, many, many things that go into producing a quality image.
For projects that demand the highest possible quality I edit in Edius (FCP works fine too) then I export the EDL. Then using a free After Effects plugin I found somewhere(don't remember where) I import that EDL into After Effects. I increase the bit depth to 32bit and my resolution to 2K. Then I do all my color correction, dissolves, graphics, and effects. From there you can send the whole project over to Encore and put together the BluRay.
Adam Grunseth is offline   Reply With Quote
Old July 26th, 2009, 03:11 AM   #4
Since Blu-Ray can use H264 or Mpeg2 you don't even need to re-encode during the authoring process. The mpeg2 transport stream files just need to be demuxed and converted into program stream files, and it would be a good idea to convert the audio into Dolby Digital AC3.
Tim Dashwood
Tim Dashwood is offline   Reply
