Recording on DR-HD100 without recording to the tape at DVinfo.net
Old May 1st, 2009, 01:30 PM   #1
OK, I used to be able to re record to my DR-HD100 from my GY-Hd100 camera without running the tape. After the service I am not able to do so, I need to record to the tape and HDD. I looked at the manual, set everything according to it and still no luck! What am I doing wrong? Advice appreciated!
Robert Rogoz is offline   Reply With Quote
Old May 1st, 2009, 04:13 PM   #2
Go into OTHERS and set the 1394 record trigger to SPLIT. This splits the REC button on the top handle to trigger just tape and the REC by the gain/WB to control just firewire recorder (DR-HD100). I think the REC button on the lens still triggers tape in SPLIT mode.
Tim Dashwood
Old May 1st, 2009, 08:35 PM   #3
Silly me, I set it up backwards on the DR-HD100. Thanks for the advice.-Robert
Old May 12th, 2009, 08:27 AM   #4
In relationship with the original post, I tried all the modes.
But I can't let the time-code continue without tape inside.
Which is a bummer, as I had several occasions that I thought the recording was not running while the DR-HD100 was recording. The small "C" blinking or continuously ON is not enough difference while filming. I feel much more comfortable seeing a time-code running in the viewfinder.
Marc Colemont - Belgium - http://www.mc-productions.be
JVC GY-HM850's, HM890, HM600
Marc Colemont is offline   Reply With Quote
Old May 12th, 2009, 10:05 PM   #5
FREE RUN TC will continually free run which will ensure that no two clips have the same TC.
Tim Dashwood
Old May 13th, 2009, 03:25 PM   #6
Thanks Tim, I'll try that tomorrow.
We are filming tomorrow with a FXMotion unit Home - Furio - Remote Controlled Dolly | FX-MOTION Great stuff.
By the way, the SPLIT mode does indeed trigger the Tape with the REC button on the lens
Old May 18th, 2009, 04:25 AM   #7
The free-run lets the time-code running indeed. But also when not recording.
I guess that's why it's called free-run...
