Macro / Close up lens at DVinfo.net
Old April 11th, 2009, 03:01 AM   #1
I have a GY-HD200 with a Th17x5BRM (82mm lens ring). I have a potential client that wants me to shoot a scientific experiment. Their company tests new pesticides and chemicals on insects and they want to video tape the results on the bugs just after they are sprayed. I tried shooting the bugs with the lens and using the macro, but that just wasn't close enough for them. Oh, the insects are bed bugs, mosquitos, flies, etc.
Can anyone recommend an inexpensive macro or close up lens that will work with the Th17x5BRM and it's 82mm thread?
Marty Jenoff
www.focalpp.com
Marty Jenoff is offline   Reply With Quote
Old April 11th, 2009, 06:38 AM   #2
Images: 10
For the cost of some negative diopter screw on lenses, you can almost afford to buy a lens mount adapter and use some used Nikon macro lenses. The adapter can be had from Mike Tapa at Untitled Document and the Nikon macro can be found on B&H's used lens department.
Old April 11th, 2009, 08:06 AM   #3
For house flies or mosquitos you can use the Th17x5BRM if you are about 4 feet away to the focal plane, set the focus ring to 3 feet, zoom in all the way, and then turn on the macro (it turns both ways - turn in the direction of the arrow.)
If you want to capture bed bugs then you will need a microscope and a microscope adapter. I own a couple microscope adapters but they are for 2/3" so you would need an ACM-17 as well.
Tim Dashwood
Old April 11th, 2009, 09:13 AM   #4
there is a very popular online auction site that usually has cheap diopter glass filters at 82mm. nuff said.
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply
