35mm Adapter Neccesary? at DVinfo.net
Old January 29th, 2009, 10:11 PM   #1
So ive seen some post talking about just directly mounting like SLR canon lenses on the end of the bayonet. Is it possible to do this with a bayonet adapter? Because Everything Ive read says you have to have a Letus or Red rock etc etc. I want a better DOF and cant get it with the stock lens.
-Cameron
Cameron Frittz is offline   Reply With Quote
Old January 29th, 2009, 10:18 PM   #2
Images: 10
This issue crops up every now and again. Mounting a 35mm lens to a 1/3 inch sensor plane won't yield a shallower DOF. What you'll get is some pretty good magnification, on the order of 7x, but, no change to the DOF.
Old January 29th, 2009, 11:10 PM   #3
So to get the enhanced DOF i would have to have an adapter?
Old January 30th, 2009, 03:39 AM   #4
The DOF of a particular focal length at a particular f stop won't change hugely between formats. However, if you use what would be a slightly wide angle focal length on a 35mm SLR onto a 1/3" video you then will have a narrower angle of view (more a telephoto lens effect).
So, if you wish to keep the angle of view of the 35mm format lens on a 1/3" or 2/3" camera you need to create a 35mm sized image that the smaller format video camera can record. Because you're using a longer focal length lens you'll have the shallower DOF. So you'd need a 35mm adapter to do this.
I'd avoid using terms like "better", because that would depend on what you're trying to do. Shooting a model for a visual effects shot you want a large DOF to create the illusion of the full sized object. Shooting a CU of a human model you may wish to have a shallow DOF - unless you're making "Citizen Kane"
Old January 30th, 2009, 07:52 AM   #5
Well im shooting more cinematic things. I have a few lenses to work with so there different depths but i would defiantly need a 35mm adapter. Can you recommend a good cheap one?
Old January 30th, 2009, 03:00 PM   #6
Letus Extreme
Brevis MP1
Redrock M2
Letus did make a version specifically for the JVC HDxxx series that mounted straight to the camera. Good luck finding on though.
Johnny Clark is offline   Reply With Quote
Old January 31st, 2009, 11:17 AM   #7
The 1st version of the HDxx compatible letus is not so ideal as it had a big crop factor. Using the stock as relay is still the best way to go in an HDxx + adapter setup.
Old January 31st, 2009, 04:51 PM   #8
Ah ic. Ok. Well what if i wanted to go about making my own Adapter? Do yall know any info on doing that?
Old January 31st, 2009, 11:40 PM   #9
Cameron,
You'll find a wealth of information in making one at the alternative imaging thread.
Alternative Imaging Methods - The Digital Video Information Network
Here's something I made
http://www.dvinfo.net/conf/alternati...mm-lenses.html
Ted
Old February 1st, 2009, 01:56 AM   #10
Thanks ted i will defiantly look into that.
Old February 2nd, 2009, 08:16 PM   #11
Ted did you make the design with a CD in it?
