Skin Detail settings with JVC HD200u at DVinfo.net
Old January 8th, 2009, 01:05 PM   #1
I am curious, should I set the skin settings on the JVC HD200u before or after I put filters in front of the camera? Including, possibly, a diffusion filter. Or, should I leave it off?
Thank you for any advice.
Jason McCormy is offline   Reply With Quote
Old January 8th, 2009, 01:16 PM   #2
If you use it do your skin tone sample after you have added filters, made your WB & other adjustments and set your exposure.
Tim Dashwood
Old January 8th, 2009, 01:20 PM   #3
Thank you very much Tim. On another note, you mentioned previously that there was a difference between the white Pro tapes and the dark grey Pro tapes. Could you elaborate on that?
Thank you as always for your extremely informative responses.
