#16 | |
This is not true. DVDITPRO-HD supports 720P fully. I just authored a feature film on blu-ray with this software and it was 720P with no transcoding at build time. |
#17 |
No takers on the mount on the KA-MR100? Oh well....
There's not much on this thread yet about the GY-HD 200 series having 720p at 50 and 60p and 1080i out by Firewire. What I like for documentary shoots are these possibilities coupled with such great lens choices and possibilities. The pursuit of higher and higher definition will always happen, but there's a certain dichotomy between that and the endless quest for a "kinder" film look. If you add 16 mm Arri Zeiss, Schneider or Cooke lenses, or say a broadcast 2/3 Fujinon or 300 Nikkor for telephoto and super telephoto shots you begin to come up with really different film like video footage that doesn't fry your retina. Look at just how many HDTV screens are wildly over-chromad (how do you spell that?) and/ or set-up as badly as they are. It makes watching poor programmes an even greater horror. It seems clear to me that channels would do better to spend on content and programme construction rather than on re-equipping yet again for even higher definition. After all, a really badly made doco on an averagely set-up 1920x1080 HDTV must be what's turning the masses to YouTube. I don't hear people clamouring for HD on YouTube so you? |
#18 | |
Not so sure about the 300mm Nikor recommendation. This would equal a 1500mm lens which is hardly practical except for extreme nature/wildlife shots, I guess. |
#19 |
Well Stefan, (and this mainly relates to the JVC GY-HD 200 (201 & 250 etc because of its image "flop" switch) I am not the master here of course, I strongly recommend that you follow lighting Cameraman Tim Dashwood who has done wonderful work on this and been good enough to share it with us.
By using the very expensive VC HZ-CA13U ARRIFLEX - GY-HD 201E LENS MOUNT, you retain all the qualities of the original (16mm) prime lenses or zoom lenses (this includes the much sort after shallow depth of field, which really changes everything on a 1/3 chip camera), the mount optically converts the image for the JVC 1/3 chip and the 200 series camera then inverts the image at capture. Yes, the longer Nikkor or 2 1/4 Hasselblad lenses or the 2/3 Broadcast lenses become wonderful wildlife kit, you would of course need serious tripod and support equipment. There are other situations which can use that sort of lens length to wonderful advantage, the compression gives you some great pull-focus possibilities.... just don't drink the night before! You can achieve much of this on the 100 series, but for a start you can't flop the image before capture. |
#20 |
First of all, since 720p holds about 20% more pixels per second then 1080i, the format is very alive. 1080p would be the next step, and camcorders that support that are either CMOS with rolling shutter or low frame rate anyway - and that's not for anyone. Since there are no 1080p50/60 camcorders our there (only lower end 1080i50/60) I would say 720p50/60 is still the best format out there.
You can DOWNconvert 720p quite easily to 1080i if you want to distribute it, or want to fit in the workflow of consumer HD (which is all 1080i). Professional production seems to have standarised 720p - and with good reason. I think 1080p is still some way off - we need cams for that first, then we need NLE's that can easily handle 1080p footage, etc etc. For now 1080i is fine for consumers and low end pro's, 720p is fine for the rather higher demanding professional productions (Varicam, ...). In a few years all will be 1080p50/60 I suppose, but for now stick with 720p.
High-Definition Video Consultant - CEO of Delimex NV - http://www.delimex.be gear of choice : http://www.wespgear.com |
#21 |
Not certain about this adaptor, but I do have the JVC HZ-CA13U 16mm adapter. I can tell you, if you slap on a Zeiss Superspeed (e.g.) prime lens you have a truly stunning image. The lens of course doesn't make the image filmlike, but the optical quality of a good cinema prime lens is truly stunning. If you see that once, and putting your standard 16x5.5 on again will make your 16x5.5 look like it's covered with dust and mud by comparison...
#22 |
Thank you Werner, an “important shout” a good correction and nicely put.
Economically speaking, (and this is relevant to the thread if you stick with me for a moment) in these "interesting times" - where banks no longer lend and advertisers are drastically cutting back, the UK’s Broadcast Regulator OFCOM has agreed that the ITV channels can't afford to go on as they are, has given them the right to basically scrap regional news programmes and cut back on others. The immediate result was that those programmes have been scrapped with a loss of 600+ staff and of course very many uncounted freelancers. So we can welcome 600+ additional freelancers on the UK market with fewer programmes to service. So what's my point? Are terrestrial broadcasters going to please Sony marketing by re-equipping yet again? Or have they learned the lesson and are too cash strapped anyway? Does anyone need to cope with the demands of 1080p at the moment? A very few maybe but otherwise I can’t really see it. I personally think JVC have got a firm grasp on all of this and "pulled a blinder" with the 200 series at 720p50/60 and by coming up with the JVC HZ-CA13U and image inverter switch and all the ergonomics of “a real camera”. As you say Werner, it's not film, but if you need film that’s already there of course. This JVC move does give a 1/3 chip camera maybe even more than people had expected or hoped for - great lenses and that seemingly impossible shallow depth of field. |
#23 |
At the moment 1080p is only interesting for indie film makers for instance - because for now, it's only available in an acceptable workflow in low framerates (24,25,30). At this point in time there's no reason to reequip for e.g. broadcasters, as there's no better alternative (i.e. 1080p50 or 1080p60).
In 2 years that'll be different, but what won't be different in 2 years? DV25 started only about 10 years ago and it is already so ancient it is long forgotten...
#24 |
That seems right apart from one thing Werner. I am still being asked for 16x9 Digital Betacam and was booked to shoot on DV25 tomorrow. Thankfully DV25 is part of the GY-HD 201E(b)'s wide arsenal of formats (or, as I just typed, "dormats" ). Isn't that the problem though? One really major broadcaster still wants Beta SP, so when can you afford to get rid of a format? Not until you can't give it away apparently.
I'm very pleased with my 201E. |
#25 |
It can happen, indeed. But you have to admit it's the furthest from 'cutting edge' that you can imagine, right?
Saying that, Broadcasters are the least progressive in their ways, as they tend to stay the longest with tried and true workflows and formats. In europe the vast majority of broadcasters is indeed still working in SD - or at least broadcasting in SD and quite possibly gathering news in SD. Productions in HD is very much standard these days, though - even if it is for eventual downconvert to SD for broadcast.
#26 |
By the way Stuart, I have the HZ-CA13U lying around here (and quite a bunch of Zeiss superspeeds). I can tell you are quite interested - feel free to contact me if you ever want to experience 16mm on the JVC GY-HD series first hand - Paris isn't that far from Antwerp.
