Sony to license XDCAM EX file format to JVC - Page 2 at DVinfo.net
Old September 13th, 2008, 10:13 AM   #16
Hi, Craig
Thanks for weighing in on this. Will there be any way to connect the XDCAM EX recorder to the HD100/HD110?
If not, will JVC be developing some kind of solid-state based recording solution for the HD100/HD110 line? Something along the lines of the recently-announced Sony compact flash recorder?
http://www.prolefeedstudios.com/blog/
Documentary for the masses!
Brian Standing is offline   Reply With Quote
Old September 13th, 2008, 03:26 PM   #17
KAMR100 IBC 2008 spinning around.
JVC HD-251 with SxS System on Vimeo
Marc Jayson is offline   Reply With Quote
Old September 13th, 2008, 04:14 PM   #18
JVC America
Originally Posted by Brian Standing View Post
Hi, Craig
No.
The only dockable solid state media recording device we have in development is the KAMR100.
Craig Yanagi - National Marketing Manager
JVC Professional Video Division, JVCKENWOOD USA Corp.
Craig Yanagi is offline   Reply With Quote
Old September 14th, 2008, 05:17 AM   #19
HD Timelapse
Will this system offer High definition Timelapse recording? I'm currently in the market for a solid state device and the abilty to record timelapse in HD is the deal clincher.
Gavin
Gavin Owens is offline   Reply With Quote
Old September 14th, 2008, 04:44 PM   #20
HDV Cinema
Hi, Craig
I hear the lust for something other than tape, but when one really looks at the COMPLETE workflow (cost and time), IMHO MiniDV tape simply can't be beat.
With Mike's ClipWrap you can import to FCP from a computer disk much like it were a camcorder disk or SxS card.
Of course, there is still the capture and conversion time, BUT were Mike to offer a version of ClipWrap with two new features you could have near "non-tape" experience.
1) Apple provides DVHScap as a kit that can be added to any program. So a tape import function could be added to ClipWrap fairly easily.
2) If anyone has used iMovie 08's HDV import function -- after firewire capture -- you see each clip in a light-table matrix and can preview each clip. Don't like it -- unclick IMPORT.
If ClipWrap had this, only the clips you wanted would be converted.
This gives the tape user the same kind of import experience as does the Sony Clip Browser. If you eliminate 50% of clips up-front you are a long way toward starting editing. And, you still have your Master tape for safe keeping!
Software like this could extend the life of the HD100 and HD110. For many who shoot 24p, these cameras are perfect.
Old September 14th, 2008, 05:43 PM   #21
Images: 1
I did... 2 1/2 years ago. XDCAM Optical was a no-brainer, offering cost per disc equal to other professional tape formats, faster than real time transfer, the ability to remove wasted shots from the disc while still acquiring, etc. The list goes on and on.
Used to it's full potential, there's no tape system that's anywhere near as efficient in both time and cost.
The cards are a bit pricey, but still offer the advantages over tape during the acquisition process.
And the NUMBER ONE REASON why tape isn't as good... You can't accidentally erase over your material with disc or card. It doesn't happen... period.
-gb-
Old September 14th, 2008, 05:59 PM   #22
Originally Posted by Tim Dashwood View Post
Not according to the specs. 25mbps for 1080i from a HD200B. 19.2Mbps for 720p on HD200/250. It seems the camera's encoder is still being used.
For now this really just means you can record directly to XDCAM EX format on a SxS card. For now there is no image quality improvement over HDV.
68-pin multi-connector.
Hmmm, that's a bit confusing. So, the initial option will be an XDCAM compressed version of an existing HDV compressed signal?
Jim Boda is offline   Reply With Quote
Old September 14th, 2008, 06:06 PM   #23
This is a big point for me; Archive. A point that gets lost IMHOP in all the tapeless excitement...
Old September 14th, 2008, 08:14 PM   #24
JVC America
That's correct. The initial capability of the KAMR100 will be to take in the video signal via IEEE 1394, internally, and wrap the signal into an XDCAM EX file.
Old September 15th, 2008, 01:34 AM   #25
Gavin
Any chance of an answer???
Old September 15th, 2008, 09:17 AM   #26
JVC America
Gavin
The GYHD250 does not have time lapse recording capability. The KAMR100 does not have time lapse recording capability currently in its specifications.
Old September 16th, 2008, 12:44 AM   #27
Pity....I was aware that the camera couldn't do so but I was hoping the next range of solid state recorders could provide a solution.Surely it's a basic need for cameras these days.
Thanks for you response
Gavin
