"ClipWrap" m2t to Quicktime HDV wrapper NOW AVAILABLE! - Page 7 at DVinfo.net
Old April 7th, 2009, 12:36 PM   #91
JVC 720p24 Workflow still an issue?
So - I feel like I have been living on another planet. Seems like everyone else has been having the JVC 720p24 to Final Cut Pro problems that I just discovered. I get it that ClipWrap is the way to get good files for FCP editing but I am still unclear on how to get the video off the tape to the m2t files. I am having problems with lots of clips and weird timecode. Do I understand that ScopeBox can capture m2t from my tapes? Something else? What is the latest, greatest workflow?
Terry VerHaar is offline   Reply With Quote
Old April 7th, 2009, 03:18 PM   #92
Hi Terry.
See my answer to your post over on the Mac forum:
http://www.dvinfo.net/conf/non-linea...ml#post1063852
David Knaggs is offline   Reply With Quote
Old April 7th, 2009, 03:26 PM   #93
Originally Posted by David Knaggs View Post
Hi Terry.
David - Thanks very, very much. I am starting to wrap my head around the various options, thanks to your input. I guess I am a little spoiled since most things in the DV world have just worked.
Terry
Old April 7th, 2009, 05:14 PM   #94
The HDVxDV demo also works for capturing m2t, as well as the Focus DR-HD100. For best results don't capture over start/stop breaks.
Tim Dashwood
Old April 8th, 2009, 09:27 AM   #95
Thanks for the info, Tim. Why does no one ever mention the MR-HD100, just the DR version? I actually just bought an MR but haven't yet had the time to try it out. Can I assume that will work, too?
(By the way - your JVC ProHD DVD has been a big boost to my learning curve!)
Terry
Old April 8th, 2009, 06:03 PM   #96
The MR-HD100 is to the FS-5 what the DR-HD100 is to the FS-4. Since the MR-HD100 and FS-5 are relatively new to the market there haven't been many first-hand accounts.
I don't own one. Maybe you could start a new thread and let us know your impressions when you try it out. I'm particularly interested in the wifi interface.
Tim Dashwood
Old April 14th, 2009, 02:30 PM   #97
Clip Wrap version 1.1.1 released
New in 1.1.1
Converts files without HDV aux packs (it will now properly convert files from DVRs or other applications - assuming they are Mpeg2/m2a streams)
Now properly detects alternate packet sizes - we can now open some TOD and m2t recordings from terrestrial or satellite sources
Now parses timecode in mpeg streams not originating from HDV cameras
Fixes issues with a/v sync on 24P/F clips from some cameras
If you have an internet connection, ClipWrap should auto update next time you launch. If not, you can grab it here: http://www.clipwrap.com/filedownload/ClipWrap 1.1.1.dmg
Tim Dashwood
Old April 19th, 2009, 07:26 PM   #98
Tim, does it mean I could re-wrap files from GZ7? Thanks
Robert Rogoz is offline   Reply With Quote
Old July 9th, 2009, 11:16 AM   #99
trimmed clip
Clipwrap misses my first second or so of video. I have this clio that a lady starts talking as soon as the clio starts, after re-wrapping I miss where she starts speaking... The clip is trimmed.
Is there any way to avoid this?
Matias Baridon is offline   Reply With Quote
Old July 11th, 2009, 04:36 AM   #100
Can't think of one. You could try MPEG Streamclip instead - it transcodes rather than just re-wrapping, but it transcodes to (among others) ProRes422, so you don't lose quality.
It's free as well.
Nick Gordon is offline   Reply With Quote
Old October 1st, 2011, 07:41 AM   #101
Re: "ClipWrap" m2t to Quicktime HDV wrapper NOW AVAILABLE!
Tim,
Many thanks for your efforts in developing Clipwrap. The conversion works perfectly from my ProHD DR-HD100 recorder M2T files to Quicktime, in the HD720-30 format. Clips a few minutes long convert in seconds!!! Then import into FCP 6.
I changed my recording setups from ".mov" to "M2T" because while recording in HD720_30p the audio has "clips" (mini signal drops or spikes), but in standard def the audio is not distorted. The distortion is not evident from tape capture in either format.
I'm using Version 3.0.3 software in the converter.
With great appreciation,
Sam Miller
MultEye-Media Productions
Sam Miller is offline   Reply With Quote
Old November 9th, 2011, 10:28 AM   #102
We have audio sync issues using ClipWrap. Using a JVC GY-HD250 at 720P60 with a Firestore set to record M2T's, we get a very consistent 13 frames of delay in the audio after unwrapping them. Taking the same files and converting them with MPGStreamclip, they are in-sync. Of course that takes forever, and I'd rather use Clipwrap and shift the audio in post than wait for MPEGStreamclip. But it would be nice if it was in sync. As it is, we have to shift every single bit of audio in post.
Any ideas about the cause?
Scott R. Smith is offline   Reply
