JVC GY-HD200 and Final Cut at DVinfo.net
Old July 14th, 2008, 07:51 AM   #1
I have been unable to get Final Cut to recognize this camera. I don't have any trouble with PC based editors, even when running Windows in boot camp. Does anyone else have this experience?
Jason McCormy is offline   Reply With Quote
Old July 14th, 2008, 08:24 AM   #2
I'm using FCP 6.0.3 and an HD200U with the "B" update (which includes the newest firmware). I have my own set of issues (regarding capture) but FCP has found the camera.
Which version of FCP are you running and what version of the firmware do you have on the camera?
As well, are you shooting HDV or DV? This may make a difference. Is the HDV/DV switch on the tape door side of the camera set to the correct setting?
Old July 14th, 2008, 01:02 PM   #3
I'm using HD and the switch is set to that. I've had no problem having it recognized by Avid and Vegas when I run bootcamp on the same machine. Final Cut is Studio 2, the latest version and updates.
Thank you very much for your help.
Old October 19th, 2008, 01:53 PM   #4
I'm considering purchasing this same camera to use with Final Cut Studio - capturing in HD. Did you get this issue worked out?
Teresa Brown is offline   Reply With Quote
Old October 21st, 2008, 11:48 AM   #5
Don't worry Teresa,
Many of us don't have these issues at all.
Dennis Robinson
G5, , 30 inch display, FCP6 Studio 2, JVC-GYHD111
Dennis Robinson is offline   Reply With Quote
Old October 21st, 2008, 04:25 PM   #6
I've seen posts about this problem more frequently lately. Just wondering what version of Quicktime you are using Jason? Is it the new 7.5 update which seems to have created problems in various different FCP scenarios. (7.5 was apparently released with iPod and iPhone priorities in mind).
As you are not having problems with other NLEs I assume your Firewire port is fine. Also assuming you are following the procedure to the letter.
Turn off computer and camera.
Connect firewire cable.
Turn on computer.
Turn on camera and set to VTR mode.
Open FCP.
Phil Balsdon is offline   Reply With Quote
Old November 1st, 2008, 04:11 PM   #7
I have found that Final Cut 6 gets unfamiliar people into a bit of trouble sometimes with the easy setup. Make sure you have closed all projects and choose a new easy setup from the FC menu. Also, make sure you have shot in hdv-hd30p or hdv-hd24p. I had a client accidentally shoot hdv-sd60p and he was having the same issues...
David Chapman
www.davechapfilms.com
David Chapman is offline   Reply With Quote
Old November 2nd, 2008, 10:44 AM   #8
Sorry I didn't catch this earlier:
Latest Version and all the updates ACTUALLY doesn't tell us what we need to know. There is a different upgrade/version number for OS 10.4 equipped systems and for 10.5 systems. I'm using FCP6.0.3 on an OS 10.4.11 with QT7.4.5
