White Shading Adjustment on 251 at DVinfo.net
Old June 19th, 2008, 02:25 PM   #1
When using the Mini35, is it recommended to adjust the White Shading for every lens (in our case a set of 4 Zeiss HS) or does one set it just once for the Mini35 (or its relay lens) ?
Up to now we've just left the shading on preset and white paint R/B on normal, with good results. But maybe some tweaking can get us an even better image.
Claude Mangold is offline   Reply With Quote
Old June 19th, 2008, 05:07 PM   #2
If the lenses are matched (all Zeiss of the same series) then it shouldn't be necessary to adjust white shading more than once. Decide on your T-stop before setting the white shading because you may see a shift as you adjust the aperture.
Tim Dashwood
Old June 23rd, 2008, 01:03 PM   #3
Tim, does this mean that the whiteshading should be adjusted basically before every take, or at leat in view of each scene's average lighting conditions ? or is this going too far ? how do you handle this in practice for optimum results ?
thanks
