Avid Hdv Problems at DVinfo.net
Old March 20th, 2008, 03:17 PM   #1
Avid Hdv Problems
I recently shot some testimonials in HDV that need to be converted to SD for an existing project. The Avid Adrenaline System is completely confused by this file format. It cannot recognize it at all.
What is the best way to capture and down convert to an SD signal. I also have adobe premiere pro 2.0.
Nicholas Ramsey is offline   Reply With Quote
Old March 20th, 2008, 05:14 PM   #2
Will your camera/deck down convert on capture?
Old March 20th, 2008, 05:19 PM   #3
It would help if you identified the format you shot in... frame rate/resolution.
Richard Alvarez is offline   Reply With Quote
Old March 22nd, 2008, 06:20 AM   #4
Did you try component out of your camera right into the Avid? Totally a wild guess but maybe worth a shot.
David Michnowicz is offline   Reply
