Panning with 24p at DVinfo.net
Old February 19th, 2008, 05:30 PM   #1
Panning with 24p
Last weekend I did some initial shooting at an archeological site using 24p for the first time to see if I like it. As a relative new user to 110U I was stunned on how nice most of my shots turned out, with the exception of my panning shots.
I panned at what i thought was an incrediably slow pace, but still saw jitters on replay. I was shooting in the fully auto mode on a stable tripod.
Are there any manual settings I should be using or should I just forget it and jump to 30?
thanks in advance,
jon
Jon R. Haskell is offline   Reply With Quote
Old February 19th, 2008, 07:19 PM   #2
Hi Jon,
It is normal behavior of progressive video and 24P. If you do a search on this forum you will bump into posts were they describe this effect, and how to deal with it.
You either pan slowly or fast. Here is a document which explains it more.
Once you read it, looking at a movie in the cinema will never be the same...
http://www.jvcpro.co.uk/getResource2...ar.pdf?id=6118
Marc Colemont - Belgium - http://www.mc-productions.be
JVC GY-HM850's, HM890, HM600
Marc Colemont is offline   Reply With Quote
Old February 19th, 2008, 10:26 PM   #3
If you reckon the JVC is bad you should try it with a DVX which has no motion smoothing!!
Personally I think the DVX is the perfect tool to learn shooting in progressive on because nothing else come close to it's filmic cadence in the sub $7,000 camcorder range. Even my Canon A1's 25f frame mode is forgiving with panning movement, lest I start slowing footage down.
JT
James Thirston is offline   Reply
